> Depending on what version of autosave you are using, you can work without any standalone autosave config files.
> Instead, you add annotations to your database records:
> record(type, "$(S):SomeRecord")
> info(autosaveFields, "VAL LOW")
> In your IOC startup file you then add a command that auto-creates the request files from those database annotations:
> makeAutosaveFileFromDbInfo("autocreated.req", "autosaveFields");
> create_monitor_set("autocreated.req.req", 5)
Again, I want the flexibility to have 1 master IOC with 20 devices to be broken in several
(i.e. let's say I reconfigure the master IOC with 15 devices and 5 single-device IOCs that actively being developed)
This should of course be transparent from the EPICS client perspective
(i.e. restored values are the same)
I understand how to generate the req file (dbgrep * > file.req or more complicated as described above)
But what about restoring the PVs, i.e. what about the sav files?
There are 2 solutions:
1/ Have one req file per device --> one sav file per device
2/ Have one req file per device --> one sav file used for all IOCs
But
1/ Limits on number of sav files in autosave
2/ I anticipate issues as several processes try to write to the same file
is there a reason why autosave is limited to 8 files?
Can this limit be raise to say ... 1000?
Better yet, can this limit be removed?
I moved away from autosave some time ago due to that limit.
Is there anything that has the same functionality as autosave but would better fit my development methodology?
Emmanuel
