Hi all, First, I am very new to Epics, so if I ask real basic questions, I am very sorry but I am trying to search alot before I ask. I installed Labview one side on Windows 7. On the other side, epics 3.15 was installed on Linux Opensuse. No problem happened. I want to connect two part using 1 router. Two has
ethernet port. I build an example using Labview. You can see the example in the following link. (http://www.ni.com/white-paper/14149/en) When I tried to read Amplitude and Frequency value in opensuse using Probe, I couldn't connect and got these values. I disabled firewall both side and their subnet is the same. Linux ip : 192.169.1.101 Windows ip: 192.169.1.100 I can reach Linux by putty, there is nothing wrong with the connection I guess. I can ping the Linux ip from the
windows. Do I need to set the variables ? export EPICS_CA_ADDR_LIST= windows ip I tried to read datas by caget but I wasn't in this too.
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
