> The downside of this
> approach is that if your DHCP/NFS/PXE/BOOTP/TFTP server or servers are
> down, nothing boots.
We use local disks and FAI (http://www.fai-project.org/). The idea is to
use PXE and NFS to boot an installation system that can
reinstall/reconfigure a broken machine in a few minutes while at the
same time being able to operate the accelerator even if the central
NFS-Server is down. Thus this avoids the single point of failure (at
least for soft-IOCs running on Linux machines).
The FAI scripts can checkout IOC configuration from your Git repository,
copy files, run Perl scripts that retrieve data from a relational
database etc.
Cheers,
Martin
Dipl. Phys. Martin Konrad
Technische Universität Darmstadt
Institut für Kernphysik
Schlossgartenstr. 9
64289 Darmstadt
Tel.: +49-6151-16-5121
Fax: +49-6151-16-4321
- Automatic IOC configuration loading Bruno Seiva Martins
- Re: Automatic IOC configuration loading Bruce Hill
Labview as Server and Probe as client, connection problem. Emir Drossa
RE: Record support for binary serial communications? peter.owens
<2013>
Re: Automatic IOC configuration loading Bruno Martins
<2013>
