This is actually something I can start to troubleshoot an maybe even help with…
I’ll start by asking you to confirm what you did a caget for. Using the names and servers in the white paper you linked to I can tell you that if you did a
caget for just Amplitude then it won’t be found, you actually have to do a caget for AE-NCARLOUGH3:Server_Library:Amplitude. In LabVIEW served PVs (except in a very specific situation that is deeply involved LabVIEW programming) the PVs will always follow
the pattern of MACHINE_NAME:LIBRARY_NAME:VARIABLE_NAME, and all three parts are what makes up the PV name to search for.
If you did use the full name (with the right pattern of upper and lower case for the PV name) it starts getting harder to sort out, but I may be able to help.
First, I am very new to Epics, so if I ask real basic questions, I am very sorry but I am trying to search alot before I ask.
I installed Labview one side on Windows 7. On the other side, epics 3.15 was installed on Linux Opensuse. No problem happened.
I want to connect two part using 1 router. Two has ethernet port.
When I tried to read Amplitude and Frequency value in opensuse using Probe, I couldn't connect and got these values.
I disabled firewall both side and their subnet is the same.
Windows ip: 192.169.1.100
I can reach Linux by putty, there is nothing wrong with the connection I guess. I can ping the Linux ip from the windows.
Do I need to set the variables ?
export EPICS_CA_ADDR_LIST= windows ip
I tried to read datas by caget but I wasn't in this too.
Scanned by iCritical.
- Labview as Server and Probe as client, connection problem. Emir Drossa
RE: Record support for binary serial communications? peter.owens
RE: MEDM won't compile in Cygwin: "Too many open files" Poff, Mark A
<2013>
[no subject] Vikram Bhagat
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
