g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: Converting raw to eng in a waveform
To: "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Cc: Kim Changseung <Changseung.Kim@iter.org>
Date: Wed, 05 Dec 2012 14:49:45 -1000
Hi Franck,
in a similar application (reading out Optomuxes) we use one
calc record per channel that converts from Optomux readout
numbers to temperatures. The slopes and intercepts are
pvLoaded at boot time (but of course can be pvloaded again
any time later as well).
Maren
Di Maio Franck wrote:
Dear all
We have a question about implementing device support for an ADC that returns values in a waveform record, not using asyn.
If we want the data to be converted from the ADC voltage range into user's engineering data, we need engineering limits or scaling factors or...
Seems that waveform is not as detailed as ai for that.
I guess that we are not the only one in the globe having this issue.
I'll appreciate to have some indication on the implementation.
Converting raw to eng in a waveform Di Maio Franck
Prev: RE: Converting raw to eng in a waveform Hill, Jeff
Next: Re: waveform put in CSS Pavel Maslov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Next: stable Linux distribution for EPICS Pavel Maslov
ANJ, 06 Dec 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
