Hi Andrew, Benjamin,
> > (A somewhat strange effect is that if I set LANG=C, then I get no
> such
> > message!)
> I can't explain that...
I think I can. Try this:
[starritt@redgum]$ touch a z A Z _
[starritt@redgum]$ ls -l
-rw-rw-r-- 1 starritt starritt 0 Oct 8 12:03 _
-rw-rw-r-- 1 starritt starritt 0 Oct 8 12:03 a
-rw-rw-r-- 1 starritt starritt 0 Oct 8 12:03 A
-rw-rw-r-- 1 starritt starritt 0 Oct 8 12:03 z
-rw-rw-r-- 1 starritt starritt 0 Oct 8 12:03 Z
[starritt@redgum]$ export LANG=C
The order that ls lists directories and files is affected by
the LANG environment variable.
With no explicit dependency rule, items added to DIRS with
DIRS := $(DIRS) $(filter-out $(DIRS), $(wildcard *App))
are build in the same order as ls lists them. I think there must be a
depencency order that is implicity being catered for when LANG is set
to C.
Regards
Andrew Starritt | Principal Controls Engineer | Australian Synchrotron
p: (03) 8540 4164 | f: (03) 8540 4200
[email protected] | www.synchrotron.org.au
800 Blackburn Road, Clayton, Victoria 3168
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Andrew Johnson
> Sent: Monday, 8 October 2012 11:48 AM
> To: [email protected]
> Subject: Re: EPICS 3.15.0 incompatible make rules
> Hi Benjamin,
> On 2012-10-07 Benjamin Franksen wrote:
> > > CLEANS += <list of files to be cleaned>
> > > ifndef BASE_3_15
> > > clean::
> > > $(RM) $(CLEANS)
> > > endif
> > What about support modules like seq? I hope the double colon rule
> means
> > that multiple clean rules (from multiple support modules) are not in
> > conflict with each other, but just wanted to make sure. If yes, I
> will
> > change the sequencer build rules accordingly.
> The sequencer build will need to adopt the above approach to be
> compatible
> with the 3.15 build rules. The double-colon rule is there for
> backwards
> compatibility with 3.14 (that's an if-not-defined BASE_3_15 condition,
> so it
> only applies for rules from older versions of Base); 3.14 uses double-
> colon
> rules for clean. I think 3.13 used a single-colon rules.
> > BTW, on my 64 bit linux (debian testing) with base-3.15.0.1, I get an
> > inexplicable
> > ben@sarun[1]: .../seq/branch-2-1 > make -sj
> > make[3]: Circular libseqDev.so. <- ../../../lib/linux-
> x86_64/libseqDev.so.
> > dependency dropped.
> > This did not happen with 3.14, I guess the new base rules add some
> extra
> > dependencies. Any idea how to fix that?
> This may be something to do with the patch mentioned below, or it might
> be
> related to a change in $(DEP) dependency rules; if it still occurs
> after
> applying the patch get back to me.
> such
> > message!)
> > Also strange: all the generated shared libraries (.so) have an extra
> > appended:
> Please read the Known Problems for 3.15 and apply the patch to fix
> that.
> HTH,
> - Andrew
> Never interrupt your enemy when he is making a mistake.
> -- Napoleon Bonaparte
- Re: EPICS 3.15.0 incompatible make rules Benjamin Franksen
- EPICS 3.15.0 incompatible make rules Dirk Zimoch
- Re: EPICS 3.15.0 incompatible make rules Andrew Johnson
<2012>
<2012>
