Hi all,
When I try to build an application including SNL, I get the following
error message:
/usr/local/epics/base-3.15.0/../seq/configure/RULES_BUILD:67: *** target
file `clean' has both : and :: entries. Stop.
The problem: The seq RULES_BUILD uses "clean::" and so does EPICS 3.14.
But EPICS 3.15 changed the clean rule to "clean:" (with only one :).
This problem may happen with many more extension packages. So can we
stay compatible in 3.15 and use :: rules where 3.14 did?
Dirk
- Re: EPICS 3.15.0 incompatible make rules Ron Sluiter
Re: waveform EDM widget Kasemir, Kay
Re: Triggered autosave on exit Tim Mooney
<2012>
Re: waveform EDM widget Hinko Kocevar
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
