g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: EPICS 3.15.0 incompatible make rules
To: tech-talk@aps.anl.gov
Date: Sun, 7 Oct 2012 19:48:17 -0500
Hi Benjamin,
On 2012-10-07 Benjamin Franksen wrote:
> > CLEANS += <list of files to be cleaned>
> > ifndef BASE_3_15
> > clean::
> >       $(RM) $(CLEANS)
> > endif
> What about support modules like seq? I hope the double colon rule means
>  that multiple clean rules (from multiple support modules) are not in
>  conflict with each other, but just wanted to make sure. If yes, I will
>  change the sequencer build rules accordingly.
The sequencer build will need to adopt the above approach to be compatible
with the 3.15 build rules.  The double-colon rule is there for backwards
compatibility with 3.14 (that's an if-not-defined BASE_3_15 condition, so it
only applies for rules from older versions of Base); 3.14 uses double-colon
rules for clean.  I think 3.13 used a single-colon rules.
> BTW, on my 64 bit linux (debian testing) with base-3.15.0.1, I get an
> inexplicable
> ben@sarun[1]: .../seq/branch-2-1 > make -sj
> make[3]: Circular libseqDev.so. <- ../../../lib/linux-x86_64/libseqDev.so.
> dependency dropped.
> This did not happen with 3.14, I guess the new base rules add some extra
> dependencies. Any idea how to fix that?
This may be something to do with the patch mentioned below, or it might be
related to a change in $(DEP) dependency rules; if it still occurs after
applying the patch get back to me.
> (A somewhat strange effect is that if I set LANG=C, then I get no such
> message!)
I can't explain that...
> Also strange: all the generated shared libraries (.so) have an extra '.'
> appended:
Please read the Known Problems for 3.15 and apply the patch to fix that.
HTH,
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
RE: EPICS 3.15.0 incompatible make rules Andrew C. Starritt
Re: EPICS 3.15.0 incompatible make rules Benjamin Franksen
EPICS 3.15.0 incompatible make rules Dirk Zimoch
Re: EPICS 3.15.0 incompatible make rules Andrew Johnson
Prev: Re: EPICS 3.15.0 incompatible make rules Benjamin Franksen
Next: RE: EPICS 3.15.0 incompatible make rules Andrew C. Starritt
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
