Dirk Zimoch wrote:
Dirk Zimoch wrote:
Installing to a different INSTALL_LOCATION fails:
make[3]: Entering directory
`/afs/psi.ch/group/8431/dirk/cvs/base-3.15.0.1/src/libCom/O.linux-x86'
perl -CSD ../../../src/libCom/env/bldEnvData.pl ../../../configure
Can't locate EPICS/Path.pm in @INC (@INC contains: ../../../lib/perl
/usr/lib/perl5/site_perl/5.8.8/i386-linux-thread-multi
/usr/lib/perl5/site_perl/5.8.8 /usr/lib/perl5/site_perl
/usr/lib/perl5/vendor_perl/5.8.8/i386-linux-thread-multi
/usr/lib/perl5/vendor_perl/5.8.8 /usr/lib/perl5/vendor_perl
/usr/lib/perl5/5.8.8/i386-linux-thread-multi /usr/lib/perl5/5.8.8 .)
at ../../../src/libCom/env/bldEnvData.pl line 20.
BEGIN failed--compilation aborted at
make[3]: Leaving directory
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory
`/afs/psi.ch/group/8431/dirk/cvs/base-3.15.0.1/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory
`/afs/psi.ch/group/8431/dirk/cvs/base-3.15.0.1/src'
make: *** [src.install] Error 2
Without setting INSTALL_LOCATION installation succeeds.
Dirk
The problem can be fixed by changing the definition of the macro PERL in
configure/CONFIG_COMMON to
PERL = perl -CSD -I $(INSTALL_PERL_MODULES)
When building modules (here asyn4-19) against an EPICS base in an
INSTALL_LOCATION, the header files in
$(EPICS_BASE)/include/os/$(OS_CLASS) are not found. With an EPICS base
without INSTALL_LOCATION it works.
Dirk
- Re: EPICS Base version 3.15.0.1 released Dirk Zimoch
- EPICS Base version 3.15.0.1 released Andrew Johnson
- Re: Re: EPICS Base version 3.15.0.1 released Dirk Zimoch
Re: Building EPICS on Mac Andrew Johnson
<2012>
<2012>
ANJ, 27 Nov 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
EPICSv4
IRMIS
Talk
Bugs
Documents
Links
Licensing
