Dirk Zimoch wrote:
Dirk Zimoch wrote:
Dirk Zimoch wrote:
Installing to a different INSTALL_LOCATION fails:
make[3]: Entering directory
`/afs/psi.ch/group/8431/dirk/cvs/base-3.15.0.1/src/libCom/O.linux-x86'
perl -CSD ../../../src/libCom/env/bldEnvData.pl ../../../configure
Can't locate EPICS/Path.pm in @INC (@INC contains: ../../../lib/perl
/usr/lib/perl5/site_perl/5.8.8/i386-linux-thread-multi
/usr/lib/perl5/site_perl/5.8.8 /usr/lib/perl5/site_perl
/usr/lib/perl5/vendor_perl/5.8.8/i386-linux-thread-multi
/usr/lib/perl5/vendor_perl/5.8.8 /usr/lib/perl5/vendor_perl
/usr/lib/perl5/5.8.8/i386-linux-thread-multi /usr/lib/perl5/5.8.8 .)
at ../../../src/libCom/env/bldEnvData.pl line 20.
BEGIN failed--compilation aborted at
make[3]: Leaving directory
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory
`/afs/psi.ch/group/8431/dirk/cvs/base-3.15.0.1/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory
`/afs/psi.ch/group/8431/dirk/cvs/base-3.15.0.1/src'
make: *** [src.install] Error 2
Without setting INSTALL_LOCATION installation succeeds.
Dirk
The problem can be fixed by changing the definition of the macro PERL
in configure/CONFIG_COMMON to
PERL = perl -CSD -I $(INSTALL_PERL_MODULES)
When building modules (here asyn4-19) against an EPICS base in an
INSTALL_LOCATION, the header files in
$(EPICS_BASE)/include/os/$(OS_CLASS) are not found. With an EPICS base
without INSTALL_LOCATION it works.
Dirk
Linux builds work (including cross embedded linux builds). I see the
problem only for vxWorks builds.
Compiling from local EPICS base:
/afs/psi.ch/project/vxworks/Tornado2.2/host/x86-linux/bin/ccppc
-DCPU=PPC604 -DvxWorks=vxWorks -include
/afs/psi.ch/project/vxworks/Tornado2.2/target/h/vxWorks.h -O -Wall
-mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall
-fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver
-I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces
-I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions
-I../../asyn/asynPortDriver -I../../asyn/devEpics
-I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014
-I../../include/compiler/gcc -I../../include/os/vxWorks -I../../include
-I/afs/psi.ch/user/z/zimoch/cvs/base-3.15.0.1/include/compiler/gcc
-I/afs/psi.ch/user/z/zimoch/cvs/base-3.15.0.1/include/os/vxWorks
-I/afs/psi.ch/project/vxworks/Tornado2.2/target/h -c
../../asyn/asynDriver/asynManager.c
All is fine, because this dir is there:
Compiling from global EPICS base:
-I/usr/local/epics/base-3.15.0/include/compiler/gcc
In file included from /usr/local/epics/base-3.15.0/include/taskwd.h:21,
from ../../asyn/asynDriver/asynManager.c:22:
/usr/local/epics/base-3.15.0/include/epicsThread.h:207: osdThread.h: No
such file or directory
In file included from ../../asyn/asynDriver/asynManager.c:25:
/usr/local/epics/base-3.15.0/include/epicsMutex.h:107: osdMutex.h: No
In file included from ../../asyn/asynDriver/asynManager.c:26:
/usr/local/epics/base-3.15.0/include/epicsEvent.h:78: osdEvent.h: No
In file included from ../../asyn/asynDriver/asynManager.c:28:
/usr/local/epics/base-3.15.0/include/epicsTime.h:19: osdTime.h: No such
file or directory
Here this dir is missing:
-I/usr/local/epics/base-3.15.0/include/os/vxWorks
This is my CONFIG.Common.T2-ppc604 configuration file (works with 3.14):
include $(CONFIG)/os/CONFIG.Common.vxWorks-ppc604_long
VXWORKS_VERSION = 5.5
WIND_BASE = /afs/psi.ch/project/vxworks/Tornado2.2
Dirk
- Re: EPICS Base version 3.15.0.1 released Dirk Zimoch
- EPICS Base version 3.15.0.1 released Andrew Johnson
- Re: Re: EPICS Base version 3.15.0.1 released Dirk Zimoch
<2012>
<2012>
