1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS Base version 3.15.0.1 released
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 13 Aug 2012 11:16:20 +0200
Installing to a different INSTALL_LOCATION fails:
make[3]: Entering directory `/afs/psi.ch/group/8431/dirk/cvs/base-3.15.0.1/src/libCom/O.linux-x86'
perl -CSD ../../../src/libCom/env/bldEnvData.pl  ../../../configure
Can't locate EPICS/Path.pm in @INC (@INC contains: ../../../lib/perl /usr/lib/perl5/site_perl/5.8.8/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.8 /usr/lib/perl5/site_perl /usr/lib/perl5/vendor_perl/5.8.8/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.8 /usr/lib/perl5/vendor_perl /usr/lib/perl5/5.8.8/i386-linux-thread-multi /usr/lib/perl5/5.8.8 .) at ../../../src/libCom/env/bldEnvData.pl line 20. BEGIN failed--compilation aborted at ../../../src/libCom/env/bldEnvData.pl line 20.
make[3]: Leaving directory `/afs/psi.ch/group/8431/dirk/cvs/base-3.15.0.1/src/libCom/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/afs/psi.ch/group/8431/dirk/cvs/base-3.15.0.1/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/afs/psi.ch/group/8431/dirk/cvs/base-3.15.0.1/src'
make: *** [src.install] Error 2
Without setting INSTALL_LOCATION installation succeeds.
Dirk
Andrew Johnson wrote:
Announcing the first developer release in the Base 3.15 series, version 3.15.0.1 is now available for download and testing. Many new features have been incorporated into the code that have been in development since 2008 and were contributed by users from many different sites. Some of the changes have not even been mentioned in the Release Notes yet, but many have. Please read the release notes to get some idea what's new. Some updates were covered in the Application Developers Guide instead (or even as well), although the changes in that document might be a bit hard to spot.
Documentation and downloads available at
    http://www.aps.anl.gov/epics/base/R3-15/0.php
Thanks to everyone who has worked on this over the last few years (and please consider writing some documentation for your contribution, it's not much use it nobody knows how to use it!).
Note: This release should not be used for operational systems, it could blow holes in your beam pipe (or insert empty beer-cans into them), quench your superconducting magnets, or adjust all your undulator gaps to zero. Actually we don't guarantee that our regular releases won't do those things by mistake either, but this release contains new code that has not been significantly tested.
- Andrew
Re: Re: EPICS Base version 3.15.0.1 released Dirk Zimoch
EPICS Base version 3.15.0.1 released Andrew Johnson
Prev: Re: EPICS Base version 3.15.0.1 released Dirk Zimoch
Next: Re: Cross-compilation, static build, etc Bruno Seiva Martins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Re: EPICS Base version 3.15.0.1 released Dirk Zimoch
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
