Hi Mark, Lewis,
On 2012-05-30 Mark Rivers wrote:
> I was able to reproduce Lewis' results on exactly the same configuration:
> MVME2100
> vxWorks 5.5.2
> EPICS 3.14.2.2
> BSP: mv2100-asd5 (by Andrew Johnson)
> I was also able to reproduce it on the MVME2700, and Lewis said he already
> reproduced it on the MVME5100. Since those constitute the vast majority
> of CPUs in use at the APS this is a serious problem. I just saw his
> message that said it goes away with -O0. L hope we can get a fixed
> cross-compiler!
Are you cross-compiling Base on a Linux or Solaris host? Please post the
output from running 'ccppc -v' so I know which compiler you're using.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- RE: calc VAL field not updating from bi VAL field Mark Rivers
- Re: calc VAL field not updating from bi VAL field J. Lewis Muir
- calc VAL field not updating from bi VAL field J. Lewis Muir
- Re: calc VAL field not updating from bi VAL field Tim Mooney
<2012>
<2012>
