1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: calc VAL field not updating from bi VAL field
To: Andrew Johnson <[email protected]>, "J. Lewis Muir" <[email protected]>
Date: Wed, 30 May 2012 21:38:45 +0000
Hi Andrew,
I am cross-compiling on Linux.
Here is the output of ccppc -v
corvette:CARS/CARSApp/src>/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc -v
Reading specs from /usr/local/vw/tornado22-ppc/host/x86-linux/lib/gcc-lib/powerpc-wrs-vxworks/gcc-2.96/specs
gcc version gcc-2.96 (2.96+) 19990621 AltiVec
Here is the output when compiling a C file for EPICS.
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc -c            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/vxWorks -I../../../include    -I/corvette/home/epics/support//allenBradley-2-2/include  -I/corvette/home/epics/support//areaDetector-1-8/include  -I/corvette/home/epics/support//asyn-4-19/include -I/corvette/home/epics/support//autosave-4-8/include/os/vxWorks -I/corvette/home/epics/support//autosave-4-8/include  -I/corvette/home/epics/support//busy-1-4/include  -I/corvette/home/epics/support//calc-2-9/include  -I/corvette/home/epics/support//camac-2-7/include        -I/corvette/home/epics/support//dxp-3-1/include    -I/corvette/home/epics/support//ipac-2-11/include  -I/corvette/home/epics/support//ip330-2-7/include     -I/corvette/home/epics/support//mca-7-1/include/os/vxWorks -I/co!
 rvette/home/epics/support//mca-7-1/include  -I/corvette/home/epics/support//modbus-2-4/include  -I/corvette/home/epics/support//motor-6-6-2/include  -I/corvette/home/epics/support//optics-2-8/include  -I/corvette/home/epics/support//quadEM-2-6/include  -I/corvette/home/epics/support//seq-2-1-7/include    -I/corvette/home/epics/support//sscan-2-7/include  -I/corvette/home/epics/support//std-3-0/include  -I/corvette/home/epics/support//stream-2-5-1/include  -I/corvette/home/epics/support//vme-2-8/include   -I/corvette/usr/local/epics/base-3.14.12.2//include/os/vxWorks -I/corvette/usr/local/epics/base-3.14.12.2//include      -I/usr/local/vw/tornado22-ppc/target/h Energy.c
Sent: Wednesday, May 30, 2012 4:33 PM
To: Mark Rivers; J. Lewis Muir
Cc: [email protected]
Subject: Re: calc VAL field not updating from bi VAL field
Hi Mark, Lewis,
On 2012-05-30 Mark Rivers wrote:
> I was able to reproduce Lewis' results on exactly the same configuration:
> MVME2100
> vxWorks 5.5.2
> EPICS 3.14.2.2
> BSP: mv2100-asd5 (by Andrew Johnson)
> I was also able to reproduce it on the MVME2700, and Lewis said he already
> reproduced it on the MVME5100.  Since those constitute the vast majority
> of CPUs in use at the APS this is a serious problem.  I just saw his
> message that said it goes away with -O0.  L hope we can get a fixed
> cross-compiler!
Are you cross-compiling Base on a Linux or Solaris host?  Please post the
output from running 'ccppc -v' so I know which compiler you're using.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
calc VAL field not updating from bi VAL field J. Lewis Muir
Re: calc VAL field not updating from bi VAL field Tim Mooney
RE: calc VAL field not updating from bi VAL field Mark Rivers
Re: calc VAL field not updating from bi VAL field Andrew Johnson
Prev: Re: calc VAL field not updating from bi VAL field Andrew Johnson
Next: Re: calc VAL field not updating from bi VAL field J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
