Lewis,
This is just bizarre. I don't see this problem on a roughly comparable VME system. I'm stumped and flailing.
Two things that I haven't seen proof of so far are that the calc record actually is processing, and that the "=" operator works.
Could you set 17lab:ClcBacklightBi.TPRO to 1, and also try "a<>1?0:1".
Could you try a calcout record, so you can check the CLCV field?
Tim
----- Original Message -----
To: "EPICS Tech Talk" <[email protected]>
Sent: Tuesday, May 29, 2012 10:09:53 PM
Subject: calc VAL field not updating from bi VAL field
I've got a problem where a calc record's VAL field is not
updating when I expect it to.
I load the following database into my IOC:
calc-bi.db >>>
record(bi, "$(P)Unidig1Bi1") {
field(ZNAM, "Low")
field(ONAM, "High")
record(calc, "$(P)ClcBacklightBi") {
field(INPA, "$(P)Unidig1Bi1.VAL CP MS")
field(CALC, "A=1?1:0")
like this:
st.cmd >>>
dbLoadRecords("calc-bi.db","P=17lab:")
I then start camonitor:
camonitor console >>>
$ camonitor 17lab:ClcBacklightBi.VAL 17lab:ClcBacklightBi.A
17lab:ClcBacklightBi.VAL 2012-05-29 19:48:44.845452 1 LINK
INVALID
17lab:ClcBacklightBi.A 2012-05-29 19:48:44.845452 0 LINK
INVALID
And then I perform a series of caput commands in another console:
caput console >>>
$ caput 17lab:Unidig1Bi1.VAL 0
Old : 17lab:Unidig1Bi1.VAL Low
New : 17lab:Unidig1Bi1.VAL Low
$ caput 17lab:Unidig1Bi1.VAL 1
New : 17lab:Unidig1Bi1.VAL High
Old : 17lab:Unidig1Bi1.VAL High
camonitor shows the following:
17lab:ClcBacklightBi.VAL 2012-05-29 21:11:28.307312 1
17lab:ClcBacklightBi.A 2012-05-29 21:11:28.307312 0
17lab:ClcBacklightBi.A 2012-05-29 21:11:33.423978 1
17lab:ClcBacklightBi.A 2012-05-29 21:11:36.990645 0
17lab:ClcBacklightBi.A 2012-05-29 21:12:32.507352 1
As you can see, the 17lab:ClcBacklightBi record's VAL field
updates once when the record first processes and then never
again. The "A" field is updating correctly as I change
17lab:Unidig1Bi1.VAL, but 17lab:ClcBacklightBi.VAL never updates
again.
If I change the CALC expression to "A", the VAL field updates
correctly. If I change it back, it stops working again.
Environment:
* VME processor module: Motorola MVME-2100 (vxWorks-ppc603)
- CPU: MPC 8240
- Memory: 32 MB
* OS: VxWorks 5.5.2
* Kernel: WIND 2.6
* BSP: mv2100-asd5 (by Andrew Johnson)
* Build toolchain: Tornado 2.2.2
* EPICS 3.14.12.2 (+Known Problems patches)
I tried this on darwin-x86 (x86_64) and it did not fail, so to
date it is only failing for me on my VME systems. (I initially
discovered the problem on an MVME-5100.)
This worked fine with older software (i.e. VxWorks 5.4.2 with
EPICS 3.14.11) on my VME systems.
Lewis
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
- Re: calc VAL field not updating from bi VAL field Tim Mooney
- Re: calc VAL field not updating from bi VAL field J. Lewis Muir
- RE: calc VAL field not updating from bi VAL field Mark Rivers
- calc VAL field not updating from bi VAL field J. Lewis Muir
Re: Proposed change in asyn - request for comments Eric Norum
<2012>
<2012>
