1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: calc VAL field not updating from bi VAL field
To: Tim Mooney <[email protected]>
Date: Wed, 30 May 2012 15:23:17 -0500
On 5/30/12 2:21 PM, Tim Mooney wrote:
> Lewis,
> This is just bizarre.  I don't see this problem on a roughly comparable VME system.  I'm stumped and flailing.
> Two things that I haven't seen proof of so far are that the calc record actually is processing, and that the "=" operator works.
> Could you set 17lab:ClcBacklightBi.TPRO to 1, and also try "a<>1?0:1".
Hi, Tim.
With 17lab:ClcBacklightBi.TPRO set to 1, every time I do a caput
to 17lab:Unidig1Bi1.VAL, I get this on the console:
17lab IOC console >>>
scanOnce: Process 17lab:ClcBacklightBi
When I set CALC to "a<>1?0:1", I get the following on the console:
Illegal field value PV: 17lab:ClcBacklightBi calc: Illegal CALC
field
17lab:ClcBacklightBi.CALC: Syntax error, unknown
operator/operand in expression "A<>1?0:1"
Instead I tried "A!=1?0:1" and "A#1?0:1" which both work correctly.
> Could you try a calcout record, so you can check the CLCV field?
The calcout record has the same problem and CLCV is 0.
Lewis
> From: "J. Lewis Muir" <[email protected]>
> To: "EPICS Tech Talk" <[email protected]>
> Sent: Tuesday, May 29, 2012 10:09:53 PM
> Subject: calc VAL field not updating from bi VAL field
> I've got a problem where a calc record's VAL field is not
> updating when I expect it to.
> I load the following database into my IOC:
> calc-bi.db >>>
> record(bi, "$(P)Unidig1Bi1") {
>   field(ZNAM, "Low")
>   field(ONAM, "High")
> record(calc, "$(P)ClcBacklightBi") {
>   field(INPA, "$(P)Unidig1Bi1.VAL CP MS")
>   field(CALC, "A=1?1:0")
> like this:
> st.cmd >>>
> dbLoadRecords("calc-bi.db","P=17lab:")
> I then start camonitor:
> camonitor console >>>
> $ camonitor 17lab:ClcBacklightBi.VAL 17lab:ClcBacklightBi.A
> 17lab:ClcBacklightBi.VAL       2012-05-29 19:48:44.845452 1 LINK
> INVALID
> 17lab:ClcBacklightBi.A         2012-05-29 19:48:44.845452 0 LINK
> INVALID
> And then I perform a series of caput commands in another console:
> caput console >>>
> $ caput 17lab:Unidig1Bi1.VAL 0
> Old : 17lab:Unidig1Bi1.VAL           Low
> New : 17lab:Unidig1Bi1.VAL           Low
> $ caput 17lab:Unidig1Bi1.VAL 1
> New : 17lab:Unidig1Bi1.VAL           High
> Old : 17lab:Unidig1Bi1.VAL           High
> camonitor shows the following:
> 17lab:ClcBacklightBi.VAL       2012-05-29 21:11:28.307312 1
> 17lab:ClcBacklightBi.A         2012-05-29 21:11:28.307312 0
> 17lab:ClcBacklightBi.A         2012-05-29 21:11:33.423978 1
> 17lab:ClcBacklightBi.A         2012-05-29 21:11:36.990645 0
> 17lab:ClcBacklightBi.A         2012-05-29 21:12:32.507352 1
> As you can see, the 17lab:ClcBacklightBi record's VAL field
> updates once when the record first processes and then never
> again.  The "A" field is updating correctly as I change
> 17lab:Unidig1Bi1.VAL, but 17lab:ClcBacklightBi.VAL never updates
> again.
> If I change the CALC expression to "A", the VAL field updates
> correctly.  If I change it back, it stops working again.
> Environment:
> * VME processor module: Motorola MVME-2100 (vxWorks-ppc603)
>   - CPU: MPC 8240
>   - Memory: 32 MB
> * OS: VxWorks 5.5.2
> * Kernel: WIND 2.6
> * BSP: mv2100-asd5 (by Andrew Johnson)
> * Build toolchain: Tornado 2.2.2
> * EPICS 3.14.12.2 (+Known Problems patches)
> I tried this on darwin-x86 (x86_64) and it did not fail, so to
> date it is only failing for me on my VME systems.  (I initially
> discovered the problem on an MVME-5100.)
> This worked fine with older software (i.e. VxWorks 5.4.2 with
> EPICS 3.14.11) on my VME systems.
> Thanks,
> Lewis
Re: calc VAL field not updating from bi VAL field Tim Mooney
Prev: Re: calc VAL field not updating from bi VAL field Eric Norum
Next: Re: ether_ip problem reading DINT arrays Bob Gunion
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: calc VAL field not updating from bi VAL field J. Lewis Muir
Next: RE: calc VAL field not updating from bi VAL field Mark Rivers
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
