1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Connection to Siemens S7 PLC
To: [email protected]
Date: Wed, 22 Feb 2012 09:40:28 -0500
As Franck said, ITER has standardized on the  S7 (300) series and the
Step 7 Professional Edition software (Windows).  We are using the ITER
configuration here with an S7-3xx and an EPICS Linux-based IOC.  We
also recently got an S7-1200 which we are  trying to get working with
the ITER software .... not there yet.  We will announce any success on
this.
-ps
On Wed, Feb 22, 2012 at 07:07, Pavel Masloff <[email protected]> wrote:
> Hello all,
> Concerning Dirk's s7plc driver (SLS) which is written for linux only, has
> anyone tried to rewrite it for windows?
> I am not that expert in drivers development, but I would be grateful if
> anyone could help me.
> >From what I can see, there are some header files (and corresponding
> libraries/functions) which are linux specific. For example,
> <unistd.h>,<sys/socket.h>, <netinet/in.h>. Perhaps, <winsock2.h> might do
> the trick?
> Maybe someone has already tried to port s7plc to Windows platform?
> On Wed, Feb 22, 2012 at 1:10 PM, Mueller, Joachim <[email protected]>
> wrote:
>> Hi,
>> just a few thoughts about the S7. It is not possible to open a Step7
>> Project for the S7-300
>> or S7-400 with Step7 MicroWin. These system do not have anything in common
>> than the
>> name and the vendor. S7-200 has a different architecture than the 300/400
>> system. And
>> therefore a completely different programming environment.
>> I have not tried yet, but I think the S7plc driver should also work with a
>> S7-1200 System
>> because it is also TCP/IP.
>> With the CP 243-1 on a S7-200 it should also work, but you cannot use the
>> example project
>> delivered with the S7plc software.
>> Greetings, Joachim
>> Joachim Mueller, Dipl.-Ing.(FH)                                 Deutsches
>> Elektronen-Synchrotron (MKK4)
>> phone:  +49-40-8998-2562
>>                                                        Notkestr. 85
>> fax:    +49-40-8994-4305
>>                                                      22607 Hamburg
>> e-mail: [email protected]
>>                                                      Germany
>> >-----Original Message-----
>> >From: [email protected] [mailto:tech-talk-
>> >[email protected]] On Behalf Of Konrad Gajewski
>> >Sent: Tuesday, February 21, 2012 1:14 PM
>> >Subject: Connection to Siemens S7 PLC
>> >Hello everybody,
>> >I'm new to EPICS and I am planning  to control Siemens Simatic S7-200
>> >PLC. I have looked in EPIC documentation and found at least two ways to
>> >connect the PLC:
>> >1. via MODBUS (Asyn) driver over the serial connection (using Siemens
>> >MODBUS RTU library)
>> >2. using S7plc driver via TCP/IP and a CP 243-1 Ethernet module.
>> >The programming of the PLC is done using Step-7 Micro/WIN V4.0.
>> >Unfortunately I can't open the example STEP 7 PLC project  (for S7plc
>> >driver) in Step-7 Micro/WIN.
>> >Do you have any experience with such a configuration or maybe with
>> >S7-1200? Are there any better options?
>> >Thanks,
>> >   Konrad
>> >Konrad Gajewski
>> >Senior Research Engineer
>> >Uppsala University                    Tel:    +46-18-4713888
>> >The Svedberg Laboratory               mailto:[email protected]
>> >Box 533, S-751 21 Uppsala, Sweden
>> >http://www.tsl.uu.se/
> Best regards,
> Pavel Maslov, MS
> Controls Engineer at Pulsed power Lab
> Efremov Institute for Electro-Physical Apparatus
> St. Petersburg, Russia
> Mobile: +7 (951) 672 22 19
> Phone: +7 (812) 461 01 01
AW: Connection to Siemens S7 PLC Rekow Jens
Connection to Siemens S7 PLC Konrad Gajewski
RE: Connection to Siemens S7 PLC Mueller, Joachim
Re: Connection to Siemens S7 PLC Pavel Masloff
Prev: RE: QT-based tools: Expressions of interest requested ian.gillingham
Next: RE: CSS X-Y Graph Chen, Xihui
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Connection to Siemens S7 PLC Pavel Masloff
Next: AW: Connection to Siemens S7 PLC Rekow Jens
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
