g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017
Subject: Connection to Siemens S7 PLC
To: tech-talk@aps.anl.gov
Date: Tue, 21 Feb 2012 13:13:43 +0100
Hello everybody,
I'm new to EPICS and I am planning to control Siemens Simatic S7-200 PLC. I have looked in EPIC documentation and found at least two ways to connect the PLC:
1. via MODBUS (Asyn) driver over the serial connection (using Siemens MODBUS RTU library)
2. using S7plc driver via TCP/IP and a CP 243-1 Ethernet module.
The programming of the PLC is done using Step-7 Micro/WIN V4.0. Unfortunately I can't open the example STEP 7 PLC project (for S7plc driver) in Step-7 Micro/WIN.
Do you have any experience with such a configuration or maybe with S7-1200? Are there any better options?
  Konrad
Konrad Gajewski
Senior Research Engineer
Uppsala University                    Tel:    +46-18-4713888
The Svedberg Laboratory               mailto:konrad.gajewski@tsl.uu.se
Box 533, S-751 21 Uppsala, Sweden
http://www.tsl.uu.se/
Re: Connection to Siemens S7 PLC Pavel Masloff
Re: Connection to Siemens S7 PLC Ralph Lange
RE: Connection to Siemens S7 PLC Mark Rivers
RE: Connection to Siemens S7 PLC Mueller, Joachim
Re: Connection to Siemens S7 PLC Rod Nussbaumer
Prev: Re: Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer) Andrew Johnson
Next: Re: Connection to Siemens S7 PLC Pavel Masloff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017
Prev: Re: Missing patch file? Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
