1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Connection to Siemens S7 PLC
To: "Konrad Gajewski" <[email protected]>, <[email protected]>
Date: Wed, 22 Feb 2012 10:10:43 +0100
just a few thoughts about the S7. It is not possible to open a Step7 Project for the S7-300
or S7-400 with Step7 MicroWin. These system do not have anything in common than the
name and the vendor. S7-200 has a different architecture than the 300/400 system. And
therefore a completely different programming environment.
I have not tried yet, but I think the S7plc driver should also work with a S7-1200 System
because it is also TCP/IP.
With the CP 243-1 on a S7-200 it should also work, but you cannot use the example project
delivered with the S7plc software.
Greetings, Joachim
Joachim Mueller, Dipl.-Ing.(FH)                                 Deutsches Elektronen-Synchrotron (MKK4)
phone:  +49-40-8998-2562        Notkestr. 85
fax:    +49-40-8994-4305        22607 Hamburg
e-mail: [email protected]        Germany
>-----Original Message-----
>From: [email protected] [mailto:tech-talk-
>[email protected]] On Behalf Of Konrad Gajewski
>Sent: Tuesday, February 21, 2012 1:14 PM
>To: [email protected]
>Subject: Connection to Siemens S7 PLC
>Hello everybody,
>I'm new to EPICS and I am planning  to control Siemens Simatic S7-200
>PLC. I have looked in EPIC documentation and found at least two ways to
>connect the PLC:
>1. via MODBUS (Asyn) driver over the serial connection (using Siemens
>MODBUS RTU library)
>2. using S7plc driver via TCP/IP and a CP 243-1 Ethernet module.
>The programming of the PLC is done using Step-7 Micro/WIN V4.0.
>Unfortunately I can't open the example STEP 7 PLC project  (for S7plc
>driver) in Step-7 Micro/WIN.
>Do you have any experience with such a configuration or maybe with
>S7-1200? Are there any better options?
>Thanks,
>   Konrad
>Konrad Gajewski
>Senior Research Engineer
>Uppsala University                    Tel:    +46-18-4713888
>The Svedberg Laboratory               mailto:[email protected]
>Box 533, S-751 21 Uppsala, Sweden
>http://www.tsl.uu.se/
Re: Connection to Siemens S7 PLC Pavel Masloff
Connection to Siemens S7 PLC Konrad Gajewski
Prev: RE: QT-based tools: Expressions of interest requested Wang Xiaoqiang
Next: Re: Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer) Goetz Pfeiffer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Connection to Siemens S7 PLC Di Maio Franck
Next: Re: Connection to Siemens S7 PLC Pavel Masloff
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
