On 21.02.2012 13:13, Konrad Gajewski wrote:
> Hello everybody,
> I'm new to EPICS and I am planning to control Siemens Simatic S7-200
> PLC. I have looked in EPIC documentation and found at least two ways
> to connect the PLC:
> 1. via MODBUS (Asyn) driver over the serial connection (using Siemens
> MODBUS RTU library)
> 2. using S7plc driver via TCP/IP and a CP 243-1 Ethernet module.
> The programming of the PLC is done using Step-7 Micro/WIN V4.0.
> Unfortunately I can't open the example STEP 7 PLC project (for S7plc
> driver) in Step-7 Micro/WIN.
> Do you have any experience with such a configuration or maybe with
> S7-1200? Are there any better options?
Using an OPC server (Siemens or third party vendor) and OPC Device
Support is a third alternative. [1]
Introduces an additional protocol layer (and IOCs running Windows), but
lets you integrate many different PLCs from different vendors in a
streamlined, uniform way.
At HZB, we were evaluating S7plc, a CAN field bus interface and OPC
Device Support, and decided to make the OPC option our future standard
for PLC integration.
~Ralph
[1] http://www-csr.bessy.de/control/SoftDist/OPCsupport/
> Thanks,
> Konrad
- Connection to Siemens S7 PLC Konrad Gajewski
Re: Connection to Siemens S7 PLC Pavel Masloff
norgren valve island Pierrick Hanlet
<2012>
RE: Connection to Siemens S7 PLC Mark Rivers
<2012>
