Hey,
As far as I am concerned, the s7plc driver works with S7-300/400 PLCs (with built-in Ethernet port or via a CP module). Not sure about the 200 series. Haven't tried it due to its absence. I presume you should properly setup the connection in Step7 (in Netview if I'm not mistaken). The s7plc driver itself is run on a PC, which initiates the connection.
Either way, I have attached an S7plc-epics manual (using a CP), if that could be of help.
On Tue, Feb 21, 2012 at 4:13 PM, Konrad Gajewski <[email protected]> wrote:
Hello everybody,
I'm new to EPICS and I am planning to control Siemens Simatic S7-200 PLC. I have looked in EPIC documentation and found at least two ways to connect the PLC:
1. via MODBUS (Asyn) driver over the serial connection (using Siemens MODBUS RTU library)
2. using S7plc driver via TCP/IP and a CP 243-1 Ethernet module.
The programming of the PLC is done using Step-7 Micro/WIN V4.0. Unfortunately I can't open the example STEP 7 PLC project (for S7plc driver) in Step-7 Micro/WIN.
Do you have any experience with such a configuration or maybe with S7-1200? Are there any better options?
Konrad
Konrad Gajewski
Senior Research Engineer
Uppsala University Tel: +46-18-4713888
The Svedberg Laboratory mailto:[email protected].se
Box 533, S-751 21 Uppsala, Sweden
http://www.tsl.uu.se/
-- Best regards,
Pavel Maslov, MS Controls Engineer at Pulsed power Lab Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
YHLhtcPLCa.pdf
Description: Adobe PDF document
- Connection to Siemens S7 PLC Konrad Gajewski
Re: Connection to Siemens S7 PLC Ralph Lange
<2012>
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
