Hi Peter,
Thanks a lot for the information. It sounds as if there is a problem in the ip330’s firmware.
I am using 4 channels of the ip330. My normal gain setting for the ip330 is 0 (equivalent to gain = 1). For now, I have implemented the logic to switch to burst continuous mode by setting the scanmode to
3 (burst continuous), then setting the gain settings for the 4 channels to 1, then setting the gain settings back to 0. This issue only seems to come up intermittently, but we will watch out for it and see if your solution resolves this issue over the long
term.
Cheers,
Jay Steele
Xradia Corporation
When I was using the ip330 in Continuous mode I found it necessary to set the gain a couple of times in my startup file in order to get it to run:
record(longout,"BL18I-EA-IONC-01:IGain")
field(PINI,"YES")
field(VAL,"0")
field(DTYP,"asynInt32")
field(OUT,"@asyn(ip330b 0)GAIN")
And in the startup file:
dbpf ("BL18I-EA-IONC-01:IGain","1")
dbpf ("BL18I-EA-IONC-01:IGain","0")
Note sure if this is relevant to you but it may be worth trying when you switch back to continuous mode.
Pete Leicester
Diamond Light Source
Hi EPICS folks,
I’m seeing a problem with the EPICS module for the VME ADC board IP330, software version 2-6. I’m trying to switch between Burst Continuous and Burst Single modes for step scanning and hardware-synchronized fly scanning, respectively,
at run time. When I process the provided ScanMode record, the board gets stuck in Burst Single mode no matter if I’m setting the Burst Continuous mode (value 3) or Burst Single mode (value 4).
Has anybody else been successful at switching modes at run time for the IP330 board using this software?
Jay Steele
Xradia Corporation
The information in this email, including any attachments, is confidential and intended only for the recipient(s) listed. Any use of this email for any other purpose
is prohibited. If you have received this email in error, please notify me immediately by reply email, delete this email, and do not disclose its contents to anyone.
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please
notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
