1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: problem with ip330-2-6 (A/D converter board) scanmode functionality to switch modes at runtime
Date: Wed, 29 Jun 2011 11:19:48 -0700
Hi EPICS folks,
     I’m seeing a problem with the EPICS module for the VME ADC board IP330, software version 2-6. I’m trying to switch between Burst Continuous and Burst Single modes for step scanning and hardware-synchronized fly scanning, respectively, at run time. When I process the provided ScanMode record, the board gets stuck in Burst Single mode no matter if I’m setting the Burst Continuous mode (value 3) or Burst Single mode (value 4).
    Has anybody else been successful at switching modes at run time for the IP330 board using this software?
Jay Steele
Xradia Corporation
The information in this email, including any attachments, is confidential and intended only for the recipient(s) listed. Any use of this email for any other purpose is prohibited. If you have received this email in error, please notify me immediately by reply email, delete this email, and do not disclose its contents to anyone.
RE: problem with ip330-2-6 (A/D converter board) scanmode functionality to switch modes at runtime peter.leicester
Prev: Re: Mantis 339 "enum string tbl cache read ASYNC IO postponed fixed" bug still around? Andrew Johnson
Next: Turbo Pump controller Zheng, Susie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Bug on alh (alarm handler) 1.2.26 alConfig.c file Andrew Johnson
Next: RE: problem with ip330-2-6 (A/D converter board) scanmode functionality to switch modes at runtime peter.leicester
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
