Subject: |
Re: Mantis 339 "enum string tbl cache read ASYNC IO postponed fixed" bug still around? |
Andrew Johnson <[email protected]> |
To: |
[email protected] |
Date: |
Wed, 29 Jun 2011 11:43:36 -0500 |
Hi Tom,
On 2011-06-24 Tom Cumming wrote:
> I'm getting the following message in our gateway log; I suspect that
> we're reproducing mantis 339, (launchpad 541367). We're running epics
> 3.14.9.
> filename="../../../../src/cas/generic/casStrmClient.cc" line
> number=1394 postpone asynchronous IO - enum string tbl cache read ASYNC IO
> postponed ?
> After I get the above message in the gateway logfile, I'm getting random
> values at random times with camonitor on some enumerated type PV's. If I
> get the same message a second time, it gets worse. Restarting the
> gateway fixes it.
> I'm wondering if mantis 339 is fixed, or simply not a problem with newer
> versions of epics. The bug was filed in '09, and I don't see any
> movement on it.
I can't answer that question myself but I'm guessing there has been no work on
it since 2009 — we have fixed CAS bugs in the more recent releases, but Jeff
Hill is usually pretty good at updating the bug tracker (Launchpad) when he
fixes something. Given the forest fires around the Los Alamos Lab right now
I'm not expecting that we'll hear from him for a while, unfortunately.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
- Mantis 339 "enum string tbl cache read ASYNC IO postponed fixed" bug still around? Tom Cumming
Re: Bug on alh (alarm handler) 1.2.26 alConfig.c file Andrew Johnson
problem with ip330-2-6 (A/D converter board) scanmode functionality to switch modes at runtime Jay Steele
<2011>
Newport XPS and Motor record John Dobbins
<2011>
