1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem in registerRecordDeviceDriver
To: Ron Sluiter <[email protected]>, [email protected]
Date: Sat, 16 Oct 2010 06:27:32 +0800
Hi, Dear Mark and Andrew,
     Thanks for your quick response! Sorry for my late response! The architecture is linux-x86, the error is kind of strange, I examined the code, it turned out the record type of waveform, motor, and scalcout etc, could not be found by the IOC modules. I found it to be of non-sense, for the transform record shared the same modules with
scalcout could be found by the modules. However, I fixed the problem by rebuild the application for scratch again. I don't know the reason it got fixed.
    And Ron, thanks for your kind remind.
     Best Regards to you
      Xinyu @ ssrf
On Fri, Oct 15, 2010 at 11:41 PM, Ron Sluiter <[email protected]> wrote:
Hello Xinyu,
May I make a suggestion?
When you ask for help on tech-talk
it is considered "good form" to
respond with a short message
indicating your problem is fixed
and possibly, how it was fixed.
This way other tech-talk users will
stop trying to help you fix the problem
and they may learn from your experience.
Ron
On 10/14/2010 8:48 PM, Xinyu Ao wrote:
     I’m using PI C-863 Mercury motor controller to control PI M-126 stage under EPICS. I currently use the 6.5.1 version for MotorSrc, PiSrc, and I
compiled successfully under EPICS version 3.14.11, with supported of packages sncseq-2.0.12, asyn4-13-1, ipac-2.10, and
calc-2-8.  However we encountered an segmentation fault error in executing st.cmd when trying to run command of xxx_registerRecordDeviceDriver pdbbase.
    could anybody give me a hint on the problem!
   Thanks
   Xinyu Ao
  SSRF
Problem in registerRecordDeviceDriver Xinyu Ao
Prev: Eurotherm Temperature Controller Support Chris Whiting
Next: Re: Problem in registerRecordDeviceDriver Xinyu Ao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Problem in registerRecordDeviceDriver Andrew Johnson
Next: CSS XY Graph show/hide traces PaweÅ PrÄdki
ANJ, 18 Oct 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
