Hi Xinyu,
On Friday 15 October 2010 17:33:08 Xinyu Ao wrote:
> I solved it by rebuilding the application. It is kind of weird.
Actually it's not weird, the order in which you compile EPICS Base, your
support modules such as Asyn and your IOC applications is important, and you
usually have to do a 'make rebuild' at the top of your IOC applications if
there changes in any of the others or if you add a new module to the
configure/RELEASE file.
> Also, I didn't know how to examine the error log for epics, could you
> tell me how to do it. I think maybe, I could get better idea of the problem
> when I examined the log.
There is no automatically generated build log, but you can create one yourself
using the tee program, the command lines below show how to do that instead of
just running plain 'make' (the commands are different depending on which shell
program you use):
sh or bash:
make 2>&1 | tee build.log
csh or tcsh:
make |& tee build.log
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it. If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence. -- Bertrand Russell
- Problem in registerRecordDeviceDriver Xinyu Ao
- Re: Problem in registerRecordDeviceDriver Andrew Johnson
- Re: Problem in registerRecordDeviceDriver Xinyu Ao
Re: Error compiling sncseq-2.0.99 on MacOSX 10.6 (Snow Leopard) and possible patch (attached) Eric Norum
Re: Manipulating time in records Andrew Johnson
<2010>
<2010>
