1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Eurotherm Temperature Controller Support
To: [email protected]
Date: Fri, 15 Oct 2010 15:26:52 -0400
I am developing an automated vacuum bakeout station for CHESS at Cornell University. I have been searching for temperature controllers which allow for 10 (or more) PID control loops, and have come across the Eurotherm 2704VC controller (this particular controller has extra inputs and outputs for vacuum equipment).
Another goal of the project, in addition to building a working bakeout station, is to use, and learn more about, the EPICS control system. I have found support written originally for the Eurotherm 800 series controllers on the Modules page, and have been told it works for the 2000 series even though it should not.
I am wondering if anyone has developed support specifically for the 2704 Eurotherm controller using the newer Modbus module or StreamDevice methods (or other newer methods), as these were not available when the support for the Eurotherm 800 series was developed.
Suggestions or comments about using the Eurotherm 2704/2500 temperature controllers for this application would also be welcomed.
Thank you for your help.
Chris Whiting
CHESS
Cornell University
RE: Eurotherm Temperature Controller Support emma.shepherd
Re: Eurotherm Temperature Controller Support Stephen Lewis
Prev: Re: IDE (was: Problem in registerRecordDeviceDriver) Ralph Lange
Next: Re: Problem in registerRecordDeviceDriver Xinyu Ao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: INLINK with PP and Asynchronous Device Support Ralph Lange
Next: RE: Eurotherm Temperature Controller Support emma.shepherd
ANJ, 18 Oct 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
