1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Cross compiling EPICS for cris v10
Cc: [email protected], Florian Feldbauer <[email protected]>
Date: Fri, 1 Oct 2010 20:46:27 +0200 (CEST)
OK now it works! Thanks a lot!
On Fri, 1 Oct 2010, Mark Rivers wrote:
OK, I the problem is that it is linking with EPICS_BASE_IOC_LIBS first,
rather than last.
slowCtrl_registerRecordDeviceDriver.o slowCtrlMain.o
-lslowCtrlSupport
-lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc
-lregistryIoc -ldbStaticIoc -lca -lCom -lstream -lasyn -lcalc
-lstreamSynApps  -lpthread    -lm -lrt
You have a mixture of PROD_LIBS and slowCtrl_LIBS, and it must be doing
PROD_LIBS after slowCtrl_LIBS.
Change
slowCtrl_LIBS += $(EPICS_BASE_IOC_LIBS)
To
PROD_LIBS += $(EPICS_BASE_IOC_LIBS)
-----Original Message----- From: Florian Feldbauer [mailto:[email protected]] Sent: Friday, October 01, 2010 1:06 PM To: Andrew Johnson Cc: [email protected]; Florian Feldbauer; Mark Rivers Subject: Re: Cross compiling EPICS for cris v10
Here's the makefile:
TOP=../..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS AFTER THIS LINE
# Build the IOC support library
LIBRARY_IOC += slowCtrlSupport
PROD_LIBS += stream
PROD_LIBS += asyn
PROD_LIBS += calc
PROD_LIBS += streamSynApps
# xxxRecord.h will be created from xxxRecord.dbd
DBDINC += xxxRecord
# Install devXxxSoft.dbd into <top>/dbd
DBD += xxxSupport.dbd
# Compile and add the code to the support library
slowCtrlSupport_SRCS += xxxRecord.c
slowCtrlSupport_SRCS += devXxxSoft.c
# Link locally-provided code into the support library,
# rather than directly into the IOC application.
slowCtrlSupport_SRCS += dbSubExample.c
slowCtrlSupport_SRCS += slowCtrlHello.c
slowCtrlSupport_SRCS += initTrace.c
slowCtrlSupport_LIBS += $(EPICS_BASE_IOC_LIBS)
# Build the IOC application
PROD_IOC = slowCtrl
# slowCtrl.dbd will be created and installed
DBD += slowCtrl.dbd
# slowCtrl.dbd will be made up from these files:
slowCtrl_DBD += base.dbd
slowCtrl_DBD += xxxSupport.dbd
slowCtrl_DBD += dbSubExample.dbd
slowCtrl_DBD += slowCtrlHello.dbd
slowCtrl_DBD += initTrace.dbd
slowCtrl_DBD += slowCtrlInclude.dbd
slowCtrl_DBD += stream.dbd
slowCtrl_DBD += asyn.dbd
# slowCtrl_registerRecordDeviceDriver.cpp derives from slowCtrl.dbd
slowCtrl_SRCS += slowCtrl_registerRecordDeviceDriver.cpp
# Build the main IOC entry point on workstation OSs.
slowCtrl_SRCS_DEFAULT += slowCtrlMain.cpp
slowCtrl_SRCS_vxWorks += -nil-
# Add support from base/src/vxWorks if needed
#slowCtrl_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
# Link in the code from the support library
slowCtrl_LIBS += slowCtrlSupport
# NOTE: To build SNL programs, SNCSEQ must be defined
# in the <top>/configure/RELEASE file
ifneq ($(SNCSEQ),)
    # Build sncExample into slowCtrlSupport
    sncExample_SNCFLAGS += +r
    slowCtrl_DBD += sncExample.dbd
    slowCtrlSupport_SRCS += sncExample.stt
    slowCtrlSupport_LIBS += seq pv
    slowCtrl_LIBS += seq pv
    # Build sncProgram as a standalone program
    PROD_HOST += sncProgram
    sncProgram_SNCFLAGS += +m
    sncProgram_SRCS += sncProgram.st
    sncProgram_LIBS += seq pv
    sncProgram_LIBS += $(EPICS_BASE_HOST_LIBS)
endif
# Finally link to the EPICS Base libraries
include $(TOP)/configure/RULES
#  ADD RULES AFTER THIS LINE
and here's the commandline: /usr/local/cris/bin/cris-axis-linux-gnu-g++ -o slowCtrl -Wl,-Bstatic -static-libgcc -Wl,--strip-all -L/usr/Epics/base-3.14.10/lib/linux-cris_v10 -L/usr/Epics/synApps/synApps_5_5/support/calc-2-8/lib/linux-cris_v10 -L/usr/Epics/slowCtrl_etrax/lib/linux-cris_v10 -L/usr/Epics/synApps/synApps_5_5/support/asyn-4-13/lib/linux-cris_v10 -L/usr/Epics/synApps/synApps_5_5/support/stream-2-4-1/lib/linux-cris_v10
-Wl,-rpath,/usr/Epics/base-3.14.10/lib/linux-cris_v10
-Wl,-rpath,/usr/Epics/synApps/synApps_5_5/support/calc-2-8/lib/linux-cri
s_v10
-Wl,-rpath,/usr/Epics/slowCtrl_etrax/lib/linux-cris_v10
-Wl,-rpath,/usr/Epics/synApps/synApps_5_5/support/asyn-4-13/lib/linux-cr
is_v10
-Wl,-rpath,/usr/Epics/synApps/synApps_5_5/support/stream-2-4-1/lib/linux
-cris_v10
-L/usr/local/devboard-R2_20//target/cris-axis-linux-gnu/lib
-L/usr/local/devboard-R2_20//target/cris-axis-linux-gnu/usr/lib
-lslowCtrlSupport
/usr/Epics/synApps/synApps_5_5/support/asyn-4-13/lib/linux-cris_v10/liba
syn.a(devAsynInt32.o):
In function `getIoIntInfo':
epicsTypeClass/../../asyn/devEpics/devAsynInt32.c:288: undefined
reference
to `epicsRingBytesCreate'
/usr/local/cris/lib/gcc-lib/cris-axis-linux-gnu/3.2.1/../../../../cris-a
xis-linux-gnu/bin/ld:
No PLT for relocation R_CRIS_32_GOTPLT against symbol
`epicsRingBytesCreate' from .text section
final link failed: Bad value
collect2: ld returned 1 exit status
make[3]: *** [slowCtrl] Error 1
make[3]: Leaving directory
`/usr/Epics/slowCtrl_etrax/slowCtrlApp/src/O.linux-cris_v10'
make[2]: *** [install.linux-cris_v10] Error 2
make[2]: Leaving directory `/usr/Epics/slowCtrl_etrax/slowCtrlApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/usr/Epics/slowCtrl_etrax/slowCtrlApp'
make: *** [slowCtrlApp.install] Error 2
Florian
On Fri, 1 Oct 2010, Andrew Johnson wrote:
On Friday 01 October 2010 07:53:33 Florian Feldbauer wrote:
I've just tested to build the example application using
makeBaseApp.pl
without changing any files. This works.
But as soon as I add Asyn and Stream I get the error.
Repeating my request of yesterday, please post your IOC's Makefile and
the command line of the link command that fails as printed by gnumake.
It's sounding more and more like this may be a mistake in your
Makefile,
that you're not linking all the libraries, or you have them in the
wrong
order.
- Andrew -- If a man is offered a fact which goes against his
instincts,
he will scrutinize it closely, and unless the evidence is
overwhelming,
he will refuse to believe it.  If, on the other hand, he is offered
something which affords a reason for acting in accordance to his
instincts, he will accept it even on the slightest evidence.  --
Bertrand Russell
Cross compiling EPICS for cris v10 Florian Feldbauer
RE: Cross compiling EPICS for cris v10 Mark Rivers
RE: Cross compiling EPICS for cris v10 Florian Feldbauer
Re: Cross compiling EPICS for cris v10 Andrew Johnson
Re: Cross compiling EPICS for cris v10 Florian Feldbauer
Prev: MOXA ARM computer and streamDevice Martin Konrad
Next: RE: MOXA ARM computer and streamDevice Hu, Yong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Cross compiling EPICS for cris v10 Mark Rivers
Next: Re: Cross compiling EPICS for cris v10 Tim Mooney
ANJ, 01 Oct 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
