Hi Martin,
I played with Moxa DA662(2 more Ethernet ports than DA661) for a while and made it work with base(3.14.10) + asyn(4.10) + StreamDevice(2.4). The cross compiler(linux-xscale_be) source code is from Moxa, but we rebuilt it. The whole cross compiling process takes some efforts. I can send you the static cross-complied executable(base, asyn and stream all included) if you want.
My application is to monitor 1-wire temperature sensors (~20K) for NSLS-2. We need 90 Moxa DA662, that's a big number. For better system maintenance and software development, I'm going to abandon Moxa DA-662 and changing to use 5 powerful and stable servers(multiple cpu cores) to handle all 1-wire stuff. Another reason I don't like Moxa DA66x is that the Linux/Debian inside Moxa has limited tools/commands so that it's painful to use.
Hope you make a good decision.
Yong
>-----Original Message-----
>From: [email protected] [mailto:tech-talk-
>[email protected]] On Behalf Of Martin Konrad
>Sent: Friday, October 01, 2010 2:20 PM
>To: EPICS tech-talk
>Subject: MOXA ARM computer and streamDevice
>Hi all,
>we are thinking about running IOCs for RS232 devices on ARM based data
>aquisition computers from MOXA (DA-661):
>http://store.moxa.com/j2bc_ext/doc/prodbase/M20090309140/DA-660-
>I_Series.pdf
>Can someone who already works with similar devices tell us if this
>should work
>with base + asyn + streamDevice? What tool-chain did you use for cross
>compiling? Did it work smoothly? What are your experiences regarding
>time
>effort for cross compiling? - Of course setting up a standard Linux PC
>together
>with a simple device server does the same job. But fewer devices/PCs
>means
>less trouble...
>best regards
>Martin
>Dipl. Phys. Martin Konrad
>Technische Universität Darmstadt
>Institut für Kernphysik
>Schlossgartenstr. 9
>64289 Darmstadt
>Tel: +49-6151-16-5121
>Fax: +49-6151-16-4321
- Re: MOXA ARM computer and streamDevice Dirk Zimoch
- MOXA ARM computer and streamDevice Martin Konrad
RE: Cross compiling EPICS for cris v10 Florian Feldbauer
Contact at Sandia Akridge, Charles S. (MSFC-ES52)
<2010>
<2010>
