TOP=../.. and here's the commandline: /usr/local/cris/bin/cris-axis-linux-gnu-g++ -o slowCtrl -Wl,-Bstatic -static-libgcc -Wl,--strip-all -L/usr/Epics/base-3.14.10/lib/linux-cris_v10 -L/usr/Epics/synApps/synApps_5_5/support/calc-2-8/lib/linux-cris_v10 -L/usr/Epics/slowCtrl_etrax/lib/linux-cris_v10 -L/usr/Epics/synApps/synApps_5_5/support/asyn-4-13/lib/linux-cris_v10 -L/usr/Epics/synApps/synApps_5_5/support/stream-2-4-1/lib/linux-cris_v10 -Wl,-rpath,/usr/Epics/base-3.14.10/lib/linux-cris_v10 -Wl,-rpath,/usr/Epics/synApps/synApps_5_5/support/calc-2-8/lib/linux-cris_v10 -Wl,-rpath,/usr/Epics/slowCtrl_etrax/lib/linux-cris_v10 -Wl,-rpath,/usr/Epics/synApps/synApps_5_5/support/asyn-4-13/lib/linux-cris_v10 -Wl,-rpath,/usr/Epics/synApps/synApps_5_5/support/stream-2-4-1/lib/linux-cris_v10 -L/usr/local/devboard-R2_20//target/cris-axis-linux-gnu/lib -L/usr/local/devboard-R2_20//target/cris-axis-linux-gnu/usr/lib slowCtrl_registerRecordDeviceDriver.o slowCtrlMain.o -lslowCtrlSupport -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lstream -lasyn -lcalc -lstreamSynApps -lpthread -lm -lrt /usr/Epics/synApps/synApps_5_5/support/asyn-4-13/lib/linux-cris_v10/libasyn.a(devAsynInt32.o): In function `getIoIntInfo': epicsTypeClass/../../asyn/devEpics/devAsynInt32.c:288: undefined reference to `epicsRingBytesCreate' /usr/local/cris/lib/gcc-lib/cris-axis-linux-gnu/3.2.1/../../../../cris-axis-linux-gnu/bin/ld: /usr/Epics/synApps/synApps_5_5/support/asyn-4-13/lib/linux-cris_v10/libasyn.a(devAsynInt32.o): No PLT for relocation R_CRIS_32_GOTPLT against symbol `epicsRingBytesCreate' from .text section /usr/local/cris/lib/gcc-lib/cris-axis-linux-gnu/3.2.1/../../../../cris-axis-linux-gnu/bin/ld: final link failed: Bad value collect2: ld returned 1 exit status make[3]: *** [slowCtrl] Error 1 make[3]: Leaving directory `/usr/Epics/slowCtrl_etrax/slowCtrlApp/src/O.linux-cris_v10' make[2]: *** [install.linux-cris_v10] Error 2 make[2]: Leaving directory `/usr/Epics/slowCtrl_etrax/slowCtrlApp/src' make[1]: *** [src.install] Error 2 make[1]: Leaving directory `/usr/Epics/slowCtrl_etrax/slowCtrlApp' make: *** [slowCtrlApp.install] Error 2 Florian On Fri, 1 Oct 2010, Andrew Johnson wrote: On Friday 01 October 2010 07:53:33 Florian Feldbauer wrote:
ANJ, 01 Oct 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
