Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017
Subject: Re: error compiling base for rtems
To: "marco_hair@163.com" <marco_hair@163.com>
Cc: tech-talk <tech-talk@aps.anl.gov>
Date: Sun, 27 Jun 2010 21:03:53 -0700
Which version of RTEMS?
On Jun 27, 2010, at 7:56 PM, "Silver" <marco_hair@163.com> wrote:
> hi,
> when I tried to compile the base3.14.10 for latest RTEMS version, it shows the following errors:
> make[3]: Entering directory `/usr/local/epics/r3.14.10/base-3.14.10/src/libCom/O.RTEMS-pc386'
> /opt/rtems/bin/i386-rtems-g++ -B/opt/rtems/i386-rtems/pc386/lib/ -specs bsp_specs -qrtems   -c   -mtune=i386               -DUNIX      -O2 -g -g  -Wall         -DOMIT_NFS_SUPPORT  -I. -I../O.Common -I. -I../../../src/libCom/osi/os/RTEMS -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/RTEMS -I../../../include         ../../../src!
 /l!
> ibCom/osi/os/RTEMS/osdTime.cpp
> ../../../src/libCom/osi/os/RTEMS/osdTime.cpp: In function 'void osdNTPInit()':
> ../../../src/libCom/osi/os/RTEMS/osdTime.cpp:61: error: 'close' was not declared in this scope
> ../../../src/libCom/osi/os/RTEMS/osdTime.cpp: At global scope:
> ../../../src/libCom/osi/os/RTEMS/osdTime.cpp:132: warning: 'done' defined but not used
> make[3]: *** [osdTime.o] Error 1
> make[3]: Leaving directory `/usr/local/epics/r3.14.10/base-3.14.10/src/libCom/O.RTEMS-pc386'
> make[2]: *** [install.RTEMS-pc386] Error 2
> make[2]: Leaving directory `/usr/local/epics/r3.14.10/base-3.14.10/src/libCom'
> make[1]: *** [libCom.install] Error 2
> make[1]: Leaving directory `/usr/local/epics/r3.14.10/base-3.14.10/src'
> make: *** [src.install] Error 2
> can anyone give some hints? thanks a lot for your help.
> Best regards
> Geyang  2010-06-28
error compiling base for rtems Silver
Prev: error compiling base for rtems Silver
Next: No PLT for relocation Dr. Peter Zumbruch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017
Next: Re: Re: error compiling base for rtems Silver
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
