1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: No PLT for relocation
To: [email protected]
Date: Mon, 28 Jun 2010 13:33:51 +0200
Hello everybody,
I am trying to cross compile and link an application based on stream device and asyn
with patched base 3.14.10 on a linux-x86_64 system with the linux-cris_v10 as target.
Stream and Asyn have been compiled for the host and target architectures.
When building the application the final linking for the target failes with this command
(which I just split up for better reading, and paths shortened <..>):
cris-g++ -o streamHadcon
-Wl,-Bstatic -static-libgcc
-Wl,--strip-all
-L<IOC_TOP>/lib/linux-cris_v10
-L<EPICS_HOME>/base/lib/linux-cris_v10
-L<EPICS_HOME>/modules/soft/StreamDevice/lib/linux-cris_v10
-L<EPICS_HOME>/modules/soft/asyn/asyn-4.11a/lib/linux-cris_v10
-Wl,-rpath,<IOC_TOP>/lib/linux-cris_v10
-Wl,-rpath,<EPICS_HOME>/base/lib/linux-cris_v10
-Wl,-rpath,<EPICS_HOME>/modules/soft/StreamDevice/lib/linux-cris_v10
-Wl,-rpath,<EPICS_HOME>/modules/soft/asyn/asyn-4.11a/lib/linux-cris_v10
-L<AXIS_TOP>/target/cris-axis-linux-gnu/lib
-L<AXIS_TOP>/target/cris-axis-linux-gnu/usr/lib
streamHadcon_registerRecordDeviceDriver.o streamHadconMain.o
-lstreamHadconSupport
-lrecIoc
-lsoftDevIoc
-lmiscIoc
-lrsrvIoc
-ldbtoolsIoc
-lasIoc
-ldbIoc
-lregistryIoc
-ldbStaticIoc
-lca
-lCom
-lstream
-lasyn
-lpthread
-lm
-lrt
resulting in this output:
<EPICS_ASYN>/lib/linux-cris_v10/libasyn.a(devAsynInt32.o): In function `getIoIntInfo':
epicsTypeClass/../../asyn/devEpics/devAsynInt32.c:288: undefined reference to `epicsRingBytesCreate'
[..]/cris-axis-linux-gnu/bin/ld: <EPICS_ASYN>/lib/linux-cris_v10/libasyn.a(devAsynInt32.o): No PLT for relocation R_CRIS_32_GOTPLT against symbol `epicsRingBytesCreate' from .text section
[..]/cris-axis-linux-gnu/bin/ld: final link failed: Bad value
collect2: ld returned 1 exit status
Notes:
- But 'epicsRingBytesCreate' is defined in libasyn.a(devAsynInt32.o), (cris-)nm gives consistent results
- Unfortunately in addition I do not fully get the meaning of the error
- It does compile for linux-x86_64
- base itself needed an independent patch for _64 architecture in base CONFIG.linux-x86_64.linux-cris(_v10/32) copy linux-x86 (to be committed soon)
Since I did the port of EPICS to cris,
has anybody else seen such a response or something similar when cross building an application?
Any help appreciated,
Thanks, Peter
Dr. rer. nat. Peter W. Zumbruch
EE - department / Controls group / GSI
E-Mail: P.Zumbruch_at_gsi.de
Tel: +49-(6159)-71-1435 / Fax: +49-(6159)-71-2986
GSI Helmholtzzentrum für Schwerionenforschung GmbH
Planckstraße 1 / D-64291 Darmstadt / www.gsi.de
Gesellschaft mit beschränkter Haftung
Sitz der Gesellschaft: Darmstadt
Handelsregister: Amtsgericht Darmstadt, HRB 1528
Geschäftsführung: Professor Dr. Dr. h.c. Horst Stöcker,
Christiane Neumann, Dr. Hartmut Eickhoff
Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph,
Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
Re: No PLT for relocation Peter Zumbruch
Re: No PLT for relocation Dr. Peter Zumbruch
Prev: Re: error compiling base for rtems Eric Norum
Next: Re: No PLT for relocation Peter Zumbruch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Re: error compiling base for rtems Silver
