1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Problems configuring 4 IK320 cards
To: <[email protected]>
Date: Tue, 22 Jun 2010 10:59:10 +0100
We are having problems configuring 4 IK320 cards to read the 4 readheads
from each of 2 Heidenhain RON905 encoders.
We have an existing system which does this successfully but we are
having difficulty setting up the second one.
We seem to be going backwards and would appreciate help diagnosing the
problem.
We are using EPICS 3.14.8.2.
We are using the IK320 driver from the vme module in synapps, release
R2-4-4
We have not managed to get 4 IK320 cards into 2 groups of 2 to
successfully work together with EPICS.
Nor do we have them interrupt with updates to the encoder value during
motion.
The system does not seem to be behaving consistently as we make changes.
In the first configuration, we used the 4 cards in slots 4&5 and 7&8
with the dip switches set as they were supplied.
The crate also contains an OMS motion control card in slot 6.
The crate also contained a Hytec carrier card with 3 ipacs in slot 9.
IK320 settings :
0x81/0x81 0x82/0x82 0x83/0x83 0x84/0x84
We had the IK32card templates set up correctly, but the group templates
were set up incorrectly.
In this configuration it was possible to read the card encoder values on
all 4 cards, but the cards were not interrupting with updates as the
axes moved.  The cards were not set on boot.
To get the groups set up and to attempt to get the interrupts working,
we changed the card settings to match the other system we have which is
working (and rebuilt the database with the new settings).
0xC1/0xC1 0xC2/0xC2 0xA1/0x80 0xA2/0x81
This time the card and group templates we used were consistent.
Unfortunately this configuration caused clashes in interrupt vector with
the Hytec cards.
We therefore attempted to make changes to avoid this clash.
0xE1/0x80 0xE2/0x81 0xC1/0x82 0xC2/0x83
This caused error messages about uninitialized interrupt vector 255,
which wisdom on the internet suggests is caused by something writing
to the wrong address.
Therefore the Hytec card was removed from slot 9 to try to make progress
and all setup and records for it scrapped from the IOC build and
returned to the configuration for the sister system.
With
We got this:
drvIK320 starting irq logger...
drvIK320: doing POST on 0xc1/0xc1
drvIK320: doing POST on 0xc2/0xc2
drvIK320: doing POST on 0xa1/0x80
filename="../drvIK320.c" line number=1218
Timeout!
filename="../drvIK320.c" line number=270
IK320 board failure.
However, suspecting a faulty bit (the 2s bit) in one of the dipswitches
on the third board we tried this.
0xC1/0xC1 0xC2/0xC2 0xA3/0x83 0xA2/0x81
In this configuration POST was successful and boards 2-4 reported their
encoder values on boot.
However board 1 could not be read.
The console gave an error message about the card being busy, however
many times you tried to do the read.
We also tried
0xC1/0x81 0xC2/0x82 0xA3/0x83 0xA2/0x84
Finally, we went back to the original configuration and defined the
groups appropriately.
The POST was OK, but card 3 could not be read, still giving the busy
message.
We decided to try to set up the groups how they should be.
0x81/0x81 0x82/0x82 0xA3/0x83 0xA4/0x84
Again POST was OK but card 3 could not be read.
We tried swapping cards 3 and 4 to see if card 3 is faulty in some way.
Card 3 still
cannot be read (was card 4).  Card 4 (was card 3) is the only one that
sets its value on boot. Cards 1 and 2 can have their encoders read.
This is evidence against the stuck 2s bit dipswitch theory.
Here is an example of the "busy message"
BL10I-MO-IOC-01 -> filename="../devIK320.c" line number=1002
ik320ReadAi() entering...
filename="../devIK320.c" line number=1037
ik320ReadAi() sending request (1st phase) failed...
filename="../devIK320.c" line number=1058
ik320ReadAi() exit (status 4090001).
IK320 card busy PV: BL10I-OP-PGM-01:MIR:ENC1:RAW ik320ReadAi()
We're struggling to know what to try next.
Thanks very much,
Linda Pratt
Software Systems Engineer
Controls Department
[email protected]
+44 (0)1235 778058
www.diamond.ac.uk
Diamond Light Source Ltd
Diamond House
Harwell Science and Innovation Campus
DIDCOT
Oxfordshire
OX11 0DE
UK
Re: Problems configuring 4 IK320 cards Ron Sluiter
RE: Problems configuring 4 IK320 cards Krempasky Juraj
Prev: MEDM installation instructions Andrew Wagner
Next: ellFree vs ellFree2 Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: MEDM installation instructions Pelaia II, Tom
Next: Re: Problems configuring 4 IK320 cards Ron Sluiter
