1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: running IOC on 80188 processor running DOS
To: tanushyam bhattacharjee <[email protected]>
Date: Tue, 25 May 2010 14:23:44 -0700
I hate to sound too discouraging, but I'm pretty sure that there's no way that you're going to be able to fit an EPICS IOC onto a machine with such limited resources.    Even running as a portable channel access service is unlikely.
Here, for example is the size of the example IOC application (on a different architecture, but I expect the sizes to be roughly the same):
   text   data    bss    dec    hex filename
1245536  32176  65024 1342736 147d10 bin/RTEMS-uC5282/example
And that's before any run-time memory allocation.
Treating the device as a 'network attached device' to an IOC running on a more capable processor is really the best approach, I think.
On May 25, 2010, at 2:06 PM, tanushyam bhattacharjee wrote:
Thanks Ralph.
>I don't think that you'll have much luck porting EPICS to a 16-bit machine.
>I'm curious as to why you'd want to use such an old architecture.
I want to run the IOC inside ADAM-5510(Advantech PC based data acquisition module,do google or http://www.advantech.com/products/ADAM-5510/mod_1-2MLE35.aspx) which consists 16 bit processor and Datalight ROM-DOS.I could have accessed the device I/O(it consists several Analog/digital input/Output modules which can be accessed by sending ASCII commands through RS232/485) using asyn by running the IOC outside.However,the module provides the facility to program outside application,hence, thought it will be nice if I can build my IOC inside without any fieldbus delay.
tanushyam
To: "tanushyam bhattacharjee" <[email protected]>
Cc: "EPICS Tech Talk" <[email protected]>
Date: Wednesday, 26 May, 2010, 1:21 AM
Also, the mail address in your email seems to be invalid, which could be
another reason for not getting mails ;-)
> The following message to <[email protected]> was undeliverable.
> The reason for the problem:
> 5.1.0 - Unknown address error 554-"delivery error: dd This user doesn't have a yahoo.co.in account ([email protected]) [0] - mta160.mail.in.yahoo.com"
Ralph
On Tue 25 May 2010 15:43:19 tanushyam bhattacharjee wrote:
> nobody has commented on this.
> Is it possible to implement all EPICS functionality if change the osi
> library as per need?
> tanushyam
> --- On *Tue, 25/5/10, tanushyam bhattacharjee /<[email protected]>/*
> wrote:
>     From: tanushyam bhattacharjee <[email protected]>
>     Subject: running IOC on 80188 processor running DOS
>     To: [email protected]
>     Date: Tuesday, 25 May, 2010, 3:38 PM
>     Is it possible to build and IOC on 80188 processor running DOS?
>     I am planning to put DOS RT kernel above DOS and build the IOC.
>     1.What are the steps I should follow?
>     2.Can I use the available base source files directly to build the IOC?
>     Tanushyam
Eric Norum
[email protected]
Re: running IOC on 80188 processor running DOS tanushyam bhattacharjee
Prev: Re: labCA and EPICS_CA_MAX_ARRAY_BYTES emmanuel_mayssat
Next: RE: labCA and EPICS_CA_MAX_ARRAY_BYTES Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: running IOC on 80188 processor running DOS tanushyam bhattacharjee
Next: Re: running IOC on 80188 processor running DOS Eric Norum
