1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: running IOC on 80188 processor running DOS
To: tanushyam bhattacharjee <[email protected]>
Cc: [email protected]
Date: Tue, 25 May 2010 12:54:34 -0700
I don't think that you'll have much luck porting EPICS to a 16-bit machine.
I'm curious as to why you'd want to use such an old architecture.
On May 25, 2010, at 12:43 PM, tanushyam bhattacharjee wrote:
nobody has commented on this.
Is it possible to implement all EPICS functionality if change the osi library as per need?
tanushyam
--- On Tue, 25/5/10, tanushyam bhattacharjee <[email protected]> wrote:
Subject: running IOC on 80188 processor running DOS
To: [email protected]
Date: Tuesday, 25 May, 2010, 3:38 PM
Is it possible to build and IOC on 80188 processor running DOS?
I am planning to put DOS RT kernel above DOS and build the IOC.
1.What are the steps I should follow?
2.Can I use the available base source files directly to build the IOC?
Tanushyam
Eric Norum
[email protected]
Re: running IOC on 80188 processor running DOS tanushyam bhattacharjee
Prev: Re: running IOC on 80188 processor running DOS Ralph Lange
Next: iPhone port Pelaia II, Tom
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: running IOC on 80188 processor running DOS Eric Norum
Next: labCA and EPICS_CA_MAX_ARRAY_BYTES John Dobbins
