The CSS DataBrowser is a superior solution including StripTool
functionality.
No idea if it runs on 64bit, though.
Ralph
On Thu 22 Apr 2010 17:47:45 [email protected] wrote:
Is there a recommended replacement for StripTool on 64-bit?
If so what is it?
E
On 13:25 Thu 22 Apr , Janet Anderson wrote:
Yes, it looks like the axis code in StripTool might need major changes.
I am looking at the code now to
see what needs to be done.
Janet
Kevin Anderson wrote:
By far the best solution is indeed to compile a 32-bit version (one way or another). It will run perfectly on a 64-bit machine.
- RE: Striptool crashes for Fedora 11 64 bit version... Kevin Anderson
- Re: Striptool crashes for Fedora 11 64 bit version... Janet Anderson
- Re: Striptool crashes for Fedora 11 64 bit version... emmanuel_mayssat
Re: Striptool crashes for Fedora 11 64 bit version... Andrew Johnson
<2010>
<2010>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
