1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Striptool crashes for Fedora 11 64 bit version...
To: [email protected]
Date: Thu, 22 Apr 2010 07:35:04 -0700
Hi All,
    Following are the two cases for which Striptool is getting crashed.
1) Striptool version 2.5.10.0 with Epics Base version 3.14.11. On the striptool graph window, right click and select toggle buttons option. If you do it one or more times, the strip toll is getting crashed. Following is the crash message.
/.../linux-x86_64/engMenu_startStripTool: line 76: 13044 Segmentation fault StripTool ${configurationDir}/${fileName}
2) Striptool version 2.5.12.0 with Epics Base version 3.14.11. On the striptool graph window, right click and select control option and immediately the striptool crashes. Following are the log messages.
==== StripTool Xt Warning Handler ====
warning:         Axis: minVal is greater than or equal to maxVal
Segmentation fault
If there are any solutions for the above problems, please let me know.
Best Regards,
Ramu
Re: Striptool crashes for Fedora 11 64 bit version... Robert Soliday
MEDM Panels disappeared frequently on Fedora Code 8 32 bit version... Ramu Denduluri
Prev: Re: GPIB secondary address Eric Norum
Next: MAXv problem Davidsaver, Michael
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Striptool crashes for Fedora 11 64 bit version... Robert Soliday
