Yes, the ASYN version of devGpib supports secondary addressing. Here's the salient portion of the documentation (devGpib.html):
An EPICS record is connected to GPIB by the fields DTYP and INP or OUT.
The DTYP field has the format:
field(DTYP,"<device support name>")
where
<device support name> - Is the name from a device database definition, i.e. a definition of the form:
device(<record type>,GPIB_IO,<dsetName>,"<device support name>")
The INP or OUT field has the format:
field(INP,"#L<link> A<addr> @<number>")
or
field(OUT,"#L<link> A<addr> @<number>")
where
<link>
Link number. Low level drivers use portName to provide access to a specific communication interface. In order to keep compatibility with link numbers, the portName MUST be Lxxx where xxx is the value that appears in the #Lxxx portion of the INP or OUT fields of record instances.
<addr>
GPIB address of your device, which can be a primary address or an extended address. A primary address has a value <=30. An extended address is of the form PSS, where P represents the primary address and SS is the secondary address. It is not possible to express an extended address if the primary address is 0. Some examples are:
A9 primary address 9
A900 extended address: primary address is 9, secondary address is 0
A906 extended address: primary address is 9, secondary address is 6.
<number>
An integer that identifies a gpibCmd definition in a GPIB device support module. If the implementer is nice, documentation like the following is provided:
recordType @<number> Description
If such documentation is not available, look at the device support itself for statements like:
/* Param 12 */
{&DSET_LI, GPIBREAD, IB_Q_LOW, "*ESR?", "%ld", 0, 20, 0, 0, 0, 0, 0, 0},
The above states that @12 is a GPIB read command via a longin record. Thus the record definition would be:
record(longin,"<name>") {
field(OUT,"#L<link> A<addr> @12")
The only drawback of this trick is that you can't have a secondary address if the primary address is 0.
On Apr 22, 2010, at 5:26 AM, Nicholas P. DiMonte wrote:
> Hi,
> How do you address the secondary addresses in a GPIB device using either R3.13 GPIB support or asynGpib support in R3.14?
> Do I need to use a convert routine and if so, how?
> Thanks,
> Nick
> Nicholas P. DiMonte
> Advanced Photon Source,
> AES Controls Group
> Argonne National Laboratory
> (630) 252-8856 [email protected]
> www.aps.anl.gov
Eric Norum
[email protected]
- GPIB secondary address Nicholas P. DiMonte
Re: GPIB secondary address Benjamin Franksen
Striptool crashes for Fedora 11 64 bit version... Ramu Denduluri
<2010>
<2010>
