1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: MEDM Panels disappeared frequently on Fedora Code 8 32 bit version...
To: [email protected]
Date: Thu, 13 May 2010 17:29:40 -0700
Hi All,
Following are different versions of EPICS Base and MEDM for which the MEDM panels getting disappeared every few hours on Fedora Core 8 32 bit operating system. There are quite a few MEDM panels that we are using and all of those panels are getting disappeared, which is causing lot of inconvenience.
1) EPICS Base 3.14.11 with MEDM versions 3.1.1, 3.1.2.1, and 3.1.4
2) EPICS Base 3.14.9 with MEDM versions 3.1.1, 3.1.2.1, and 3.1.4
3) EPICS Base 3.14.6 with MEDM version 3.0.3, which was working version on Redhat 8. Last year, we migrated all our software to Fedora 8 32 bit version.
Could anyone point me to the correct versions of EPICS Base and MEDM, which works fine.
Best Regards,
Ramu
RE: MEDM Panels disappeared frequently on Fedora Code 8 32 bit version... Mark Rivers
Re: MEDM Panels disappeared frequently on Fedora Code 8 32 bit version... Robert Soliday
Striptool crashes for Fedora 11 64 bit version... Ramu Denduluri
Prev: Argonne Network Maintenance this weekend Andrew Johnson
Next: RE: MEDM Panels disappeared frequently on Fedora Code 8 32 bit version... Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Striptool crashes for Fedora 11 64 bit version... Robert Soliday
