1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: MBBO update
To: "Hinko Kocevar" <[email protected]>, <[email protected]>
Date: Thu, 11 Feb 2010 07:51:55 -0600
Hi Hinko,
This is a classic problem of having more than one mechanism for driving an output, and keeping the output PV up-to-date.
Here is a database fragment that handles this logic (thanks to Tim Mooney for this).
FileNumber is the output record, the equivalent of the mbbo record in your case.  Note that it uses soft device support, it does not talk directly to the hardware.  FileNumber_RBV is the input record, the equivalent of the mbbi record in your case.  In my case it it I/O Intr scanned, i.e. it processes when the hardware driver does a callback to device support, but it could also be periodically scanned. There are 2 additional records required.  FileNumber_write is the record that actually talks to the hardware.  FileNumber_Sync is a record that copies the readback value from FileNumber_RBV to FileNumber, but WITHOUT causing the value to be written to the hardware.  It works because the FileNumber_write record has scan disabled if the FileNumber_sync record is processing (PACT=1).  With this logic FileNumber will correctly reflect the actual state of the hardware, and it can also be written to change the hardware.
record(longout, "$(P)$(R)FileNumber")
    field(PINI, "YES")
    field(OUT, "$(P)$(R)FileNumber_write PP")
    field(VAL, "1")
record(longout, "$(P)$(R)FileNumber_write")
    field(SDIS, "$(P)$(R)FileNumber_Sync.PACT")
    field(DISV, "1")
    field(DTYP, "asynInt32")
    field(OUT, "@asyn($(PORT),$(ADDR),$(TIMEOUT))FILE_NUMBER")
record(longin, "$(P)$(R)FileNumber_RBV")
    field(INP,  "@asyn($(PORT),$(ADDR),$(TIMEOUT))FILE_NUMBER")
    field(SCAN, "I/O Intr")
    field(FLNK, "$(P)$(R)FileNumber_Sync")
record(longout, "$(P)$(R)FileNumber_Sync")
    field(DOL,  "$(P)$(R)FileNumber_RBV NPP")
    field(OMSL, "closed_loop")
    field(OUT,  "$(P)$(R)FileNumber PP")
Sent: Thu 2/11/2010 6:27 AM
To: [email protected]
Subject: MBBO update
I'm using mbbo record type that provides 5 values/strings. When mbbo
record is controlled from EDM panel using Radio Box I can set the record
value to desired state.
If the state changes in the underlying software my mbbo record does not
update the value - eg. Radio Box button that was last pressed remains
selected in the EDM panel, while actual state changed.
How can this be done?
Providing mbbi record with same PORT and ADDR as mbbo, I can see that
the state in mbbi record updates as soon as the underlying software
changes the value. But this does not update the mbbo record, though..
Here is the mbbo record:
record(mbbo, "$(DEVICE)SWITCH") {
        field(OUT, "@asyn($(PORT), 0, 1.0)")
        field(ZRVL, "0")
        field(ONVL, "1")
        field(TWVL, "2")
        field(THVL, "3")
        field(FRVL, "4")
        field(ZRST, "MANUAL")
        field(ONST, "AUTO")
        field(TWST, "AVERAGING")
        field(THST, "COMPENSATING")
        field(FRST, "AVE & COMP")
        field(PINI, "YES")
Best regards,
Hinko
Hinko Kocevar
Technical support software engineer
Instrumentation Technologies
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si <http://www.i-tech.si/>  - When your users demand stability
The information transmitted is intended solely for the addressee and may
contain confidential and/or privileged information. Any review, retention,
disclosure or other use by persons other than the intended recipient is
prohibited. If you received this in error, please notify the sender and
delete all copies.
Re: MBBO update Ralph Lange
Re: MBBO update Stephen Lewis
MBBO update Hinko Kocevar
Prev: MBBO update Hinko Kocevar
Next: EPICS_CA_MAX_ARRAY_BYTES Matthieu Bec
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: MBBO update Ralph Lange
