1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: EPICS_CA_MAX_ARRAY_BYTES
To: epics <[email protected]>
Date: Thu, 11 Feb 2010 12:35:52 -0300
I need a check from the experts my understanding of channel access is correct.
http://www.aps.anl.gov/epics/base/R3-14/10-docs/CAref.html#Configurin1
We have a couple of systems in development for which I'd like to use the EPICS_CA_MAX_ARRAY_BYTES feature, quite extensively at up to 4.2MB.
Nothing from the legacy infrastructure (either clients or servers) will need access the new big arrays, but there will be interchanges for 'regular' (<4k) records between the new servers and its legacy surroundings.
Only dedicated clients will be accessing the big arrays, they'll also access regular records, both from the legacy and new systems.
As I read it, anything 'regular' goes on the 4k freelist, compatible for all the systems. Anything else has a dedicated EPICS_CA_MAX_ARRAY_BYTES freelist. So there's no cross talk and it all plays nicely.
check?
Matthieu
-- Matthieu Bec Gemini Observatory Tel: +56 51 205785 c/o AURA, Casilla 603 Fax: +56 51 205650 La Serena, Chile
Prev: RE: MBBO update Mark Rivers
Next: Re: MBBO update Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: EPICS/asyn problem Mark Rivers
