I'm using mbbo record type that provides 5 values/strings. When mbbo
record is controlled from EDM panel using Radio Box I can set the record
value to desired state.
If the state changes in the underlying software my mbbo record does not
update the value - eg. Radio Box button that was last pressed remains
selected in the EDM panel, while actual state changed.
How can this be done?
Providing mbbi record with same PORT and ADDR as mbbo, I can see that
the state in mbbi record updates as soon as the underlying software
changes the value. But this does not update the mbbo record, though..
Here is the mbbo record:
record(mbbo, "$(DEVICE)SWITCH") {
field(DTYP, "asynInt32")
field(OUT, "@asyn($(PORT), 0, 1.0)")
field(ZRVL, "0")
field(ONVL, "1")
field(TWVL, "2")
field(THVL, "3")
field(FRVL, "4")
field(ZRST, "MANUAL")
field(ONST, "AUTO")
field(TWST, "AVERAGING")
field(THST, "COMPENSATING")
field(FRST, "AVE & COMP")
field(PINI, "YES")
Best regards,
Hinko
Hinko Kocevar
Technical support software engineer
Instrumentation Technologies
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the addressee and may
contain confidential and/or privileged information. Any review, retention,
disclosure or other use by persons other than the intended recipient is
prohibited. If you received this in error, please notify the sender and
delete all copies.
- RE: MBBO update Mark Rivers
Intel C Compiler icc on linux? Carl Lionberger
<2010>
<2010>
