hi, Mark:
More questions, can the areaDector support for other camera such as DALSA's product which compliants with GIGE standard? or it only support Prosilica?
======= At 2009-11-22, 08:41:46 you wrote: =======
>I just double-checked my system and I realized actually ran into the same problem with libnet 1.1.2.1-11 a couple of years ago. I fixed it by simply removing the "inline" keyword from that line in libnet-functions.h.
>I looked at a more recent version of libnet (1.1.4-3) and the inline keyword is not present in that version of libnet-functions.h
>Mark
>________________________________
>From: [email protected] on behalf of Bruce Hill
>Sent: Fri 11/20/2009 8:51 PM
>To: [email protected]
>Cc: tech-talk
>Subject: Re: error building mca6-11
>I had a similar problem where I needed to compile some code
>I was sharing with a non-epics app and I needed to compile it
>without -ansi.
>Turning it off in epics base config files is asking for trouble as it
>will affect all compiles of base, modules, IOC's, etc.
>Since -ansi is selecting the language standard, you can't just turn it off
>with a compile flag. Instead, you have to select a different language
>standard. The default gnu std for c files is gnu89, but others are
>available as well, such as c89, c99, gnu99, etc. See the gcc man page
>for details.
>For my directory that had this problem, I added the following line in that
>directory's Makefile after including $(TOP)/configure/CONFIG.
> USR_CFLAGS += -std=gnu99
>- Bruce Hill
>Silver wrote:
> hi, Michael:
> so how to solve it? close the ansi switch in epics base's configure files? will it influence the base?
> ======= At 2009-11-20, 22:41:31 you wrote: =======
> This is an '-ansi' problem.
> On my Debian system (libnet 1.1.2.1-2) line 1432 of libnet-functions.h
> looks like
> inline u_int32_t
> The 'inline' keyword isn't part of ANSI C89 and can't be used when
> compiling with '-ansi', which EPICS Base does by default.
> Michael Davidsaver
> NSLSII Controls Group
> Brookhaven National Lab
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Silver
> Sent: Friday, November 20, 2009 12:28 AM
> To: tech-talk
> Subject: error building mca6-11
> hi,
> when I tried to compile the mcaR6-11/10, I met following errors:
> /usr/bin/gcc-4.2 -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -
> D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -
> D_REENTRANT -ansi -O3 -Wall -g `libnet-config --defines`
> -m32
> -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -
> I../../../include -I/usr/local/epics/r3.14.10/modules/soft/seq/2-0-
> 12/include
> -I/usr/local/epics/r3.14.10/modules/soft/calc/2-6-7/include
> -I/usr/local/epics/r3.14.10/modules/soft/sscan/2-6-5/include -
> I/usr/local/epics/r3.14.10/modules/soft/busy/1-1/include -
> I/usr/local/epics/r3.14.10/modules/soft/std/2-6/include -
> I/usr/local/epics/r3.14.10/modules/soft/asyn/4-12/include -
> I/usr/local/epics/r3.14.10/modules/soft/mca/6-11/include/os/Linux -
> I/usr/local/epics/r3.14.10/modules/soft/mca/6-11/include -
> I/usr/local/epics/r3.14.10/base/include/os/Linux -
> I/usr/local/epics/r3.14.10/base/include ../nmc_comm_subs_1.c
> In file included from /usr/include/libnet.h:124,
> from ../nmc_sys_defs.h:56,
> from ../nmc_comm_subs_1.c:69:
> /usr/include/./libnet/libnet-functions.h:1432: error: expected '=',
> ',', ';', 'asm' or '__attribute__' before 'u_int32_t'
> make[3]: *** [nmc_comm_subs_1.o] Error 1
> make[3]: Leaving directory
> `/usr/local/epics/r3.14.10/modules/soft/mca/6-
> 11/mcaApp/CanberraSrc/O.linux-x86'
> make[2]: *** [install.linux-x86] Error 2
> make[2]: Leaving directory
> `/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp/CanberraSrc'
> make[1]: *** [CanberraSrc.install] Error 2
> make[1]: Leaving directory
> `/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp'
> make: *** [mcaApp.install] Error 2
> root@cow1:/usr/local/epics/r3.14.10/modules/soft/mca/6-11#
> Any suggestion? thanks a lot.
> ps, I use ubuntu, libnet1 with apt-get install ,not from source
> compilation.
> Best regards
> Geyang 2009-11-20
> Best regards
> Geyang 2009-11-21
>Bruce Hill
>Member Technical Staff
>SLAC National Accelerator Lab
>2575 Sand Hill Road M/S 94
>Menlo Park, CA 94025
Best regards
Geyang 2009-11-27
- RE: RE: error building mca6-11 Mark Rivers
- error building mca6-11 Silver
- RE: error building mca6-11 Davidsaver, Michael
- Re: RE: error building mca6-11 Silver
- Re: error building mca6-11 Bruce Hill
- RE: error building mca6-11 Mark Rivers
Re: DEC driver DMA Underflow Andrew Johnson
<2009>
<2009>
