1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: DEC driver DMA Underflow
To: [email protected]
Date: Wed, 25 Nov 2009 17:03:42 -0600
Mark, Matt,
On Wednesday 25 November 2009 15:23:15 Mark Rivers wrote:
> I don't know upgrading to 3.14.x will fix that, I have had problems that
> sound similar on MVME2700 on 3.14.8.2 and 3.14.10.  But I don't recall
> seeing the DMA underflow message. The network goes belly up and cannot
> recover, though everything else looks OK.  Andrew Johnson made a change
> to the BSP recently that he though might address the issue, but I have
> not tested it.  On the other hand this has not happened for many months
> now.  Sometimes it happened every week.
That was exactly the issue that caused me to release the new BSP.  Upgrading
to R3.14.x will not help, because the dec driver basically locks up the
network when this happens.
The fix is actually to simplify the code that Matt posted, replacing
everything after the LOG_MSG as follows:
> /* restart tx if DMA underflow is detected */
> if (pTxD->tDesc0 & PCISWAP(TDESC0_UF))
>   LOG_MSG ("%s%d - DMA underflow\n",
>   (int) DRV_NAME, pDrvCtrl->unit, 0, 0, 0, 0);
>    if (DRV_FLAGS_ISSET(DEC_TX_KICKSTART))
>        DEC_CSR_WRITE (CSR1, CSR1_TPD);
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
DEC driver DMA Underflow Matt Rippa
RE: DEC driver DMA Underflow Mark Rivers
Prev: Re: DEC driver DMA Underflow Matt Rippa
Next: Re: RE: error building mca6-11 Silver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: DEC driver DMA Underflow Jeff Hill
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
