I just double-checked my system and I realized actually ran into the same problem with libnet 1.1.2.1-11 a couple of years ago. I fixed it by simply removing the "inline" keyword from that line in libnet-functions.h.
I looked at a more recent version of libnet (1.1.4-3) and the inline keyword is not present in that version of libnet-functions.h
Sent: Fri 11/20/2009 8:51 PM
To: [email protected]
Cc: tech-talk
Subject: Re: error building mca6-11
I had a similar problem where I needed to compile some code
I was sharing with a non-epics app and I needed to compile it
without -ansi.
Turning it off in epics base config files is asking for trouble as it
will affect all compiles of base, modules, IOC's, etc.
Since -ansi is selecting the language standard, you can't just turn it off
with a compile flag. Instead, you have to select a different language
standard. The default gnu std for c files is gnu89, but others are
available as well, such as c89, c99, gnu99, etc. See the gcc man page
for details.
For my directory that had this problem, I added the following line in that
directory's Makefile after including $(TOP)/configure/CONFIG.
USR_CFLAGS += -std=gnu99
- Bruce Hill
Silver wrote:
hi, Michael:
so how to solve it? close the ansi switch in epics base's configure files? will it influence the base?
======= At 2009-11-20, 22:41:31 you wrote: =======
This is an '-ansi' problem.
On my Debian system (libnet 1.1.2.1-2) line 1432 of libnet-functions.h
looks like
inline u_int32_t
The 'inline' keyword isn't part of ANSI C89 and can't be used when
compiling with '-ansi', which EPICS Base does by default.
Michael Davidsaver
NSLSII Controls Group
Brookhaven National Lab
-----Original Message-----
[email protected]] On Behalf Of Silver
Sent: Friday, November 20, 2009 12:28 AM
To: tech-talk
Subject: error building mca6-11
hi,
when I tried to compile the mcaR6-11/10, I met following errors:
/usr/bin/gcc-4.2 -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -
D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -
D_REENTRANT -ansi -O3 -Wall -g `libnet-config --defines`
-m32
-g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -
I../../../include -I/usr/local/epics/r3.14.10/modules/soft/seq/2-0-
12/include
-I/usr/local/epics/r3.14.10/modules/soft/calc/2-6-7/include
-I/usr/local/epics/r3.14.10/modules/soft/sscan/2-6-5/include -
I/usr/local/epics/r3.14.10/modules/soft/busy/1-1/include -
I/usr/local/epics/r3.14.10/modules/soft/std/2-6/include -
I/usr/local/epics/r3.14.10/modules/soft/asyn/4-12/include -
I/usr/local/epics/r3.14.10/modules/soft/mca/6-11/include/os/Linux -
I/usr/local/epics/r3.14.10/modules/soft/mca/6-11/include -
I/usr/local/epics/r3.14.10/base/include/os/Linux -
I/usr/local/epics/r3.14.10/base/include ../nmc_comm_subs_1.c
In file included from /usr/include/libnet.h:124,
from ../nmc_sys_defs.h:56,
from ../nmc_comm_subs_1.c:69:
/usr/include/./libnet/libnet-functions.h:1432: error: expected '=',
',', ';', 'asm' or '__attribute__' before 'u_int32_t'
make[3]: *** [nmc_comm_subs_1.o] Error 1
make[3]: Leaving directory
`/usr/local/epics/r3.14.10/modules/soft/mca/6-
11/mcaApp/CanberraSrc/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory
`/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp/CanberraSrc'
make[1]: *** [CanberraSrc.install] Error 2
make[1]: Leaving directory
`/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp'
make: *** [mcaApp.install] Error 2
root@cow1:/usr/local/epics/r3.14.10/modules/soft/mca/6-11#
Any suggestion? thanks a lot.
ps, I use ubuntu, libnet1 with apt-get install ,not from source
compilation.
Best regards
Geyang 2009-11-20
Best regards
Geyang 2009-11-21
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 94
Menlo Park, CA 94025
- Re: RE: error building mca6-11 Silver
- error building mca6-11 Silver
- RE: error building mca6-11 Davidsaver, Michael
- Re: error building mca6-11 Bruce Hill
RE: RE: RE: error building mca6-11 Mark Rivers
Fwd: CA link behavior Geoff Savage
<2009>
<2009>
