Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017
Subject: RE: Modbus help
To: <rivers@cars.uchicago.edu>, <tech-talk@aps.anl.gov>
Date: Wed, 25 Nov 2009 09:37:06 -0000
Hi Mark,
I've attached my startup script (the modbus stuff is at the bottom).
There are actually 8 devices in an RS-485 chain, at the moment I'm just
trying to talk to the one which is configured with address '1' (although
I have tried the others as well).  They use serial/RTU.
I turned on trace for the Modbus port as well, here's what I get:
01 03 00 01 00 01 d5 ca
2009/11/25 09:33:41.823 drvModbusAsyn::doModbusIO port readTemp error
calling writeRead, error=, nwrite=5/5, nread=0
2009/11/25 09:33:42.173 readTemp queueRequest synchronous
2009/11/25 09:33:42.173 ME02P-DI-TMON-01:TEMP1 devAsynFloat64::process
read error
2009/11/25 09:33:43.323 drvModbusAsyn::doModbusIO port readTemp has I/O
error
disconnect device OK
2009/11/25 09:33:43.323 drvModbusAsyn::doModbusIO port readTemp connect
device OK
2009/11/25 09:33:43.323 /ty/72/0 write 8
2009/11/25 09:33:44.823 drvModbusAsyn::doModbusIO port readTemp error
2009/11/25 09:33:46.323 drvModbusAsyn::doModbusIO port readTemp has I/O
error
2009/11/25 09:33:46.323 drvModbusAsyn::doModbusIO port readTemp connect
device OK
2009/11/25 09:33:46.323 /ty/72/0 write 8
Thanks a lot,
Emma
> -----Original Message-----
> From: Mark Rivers [mailto:rivers@cars.uchicago.edu]
> Sent: 24 November 2009 17:32
> To: Shepherd, Emma (DLSLtd,RAL,DIA); tech-talk@aps.anl.gov
> Hi Emma,
> Here are some questions/suggestions:
> - Can you send your startup script?
> - How have you set the interpose interface, etc?
> - Does your device use serial/RTU (binary) or serial/ASCII protocol?
> - What is the slave address of your device?
> - You have turned on asynTrace for the underlying asyn serial
> port. Please also turn on asynTrace for the Modbus asyn port.
>  That should be very helpful.
> Once I know how it is configured I can figure out if those 8
> characters it is sending are correct.
> Mark
> From: tech-talk-bounces@aps.anl.gov
> [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of
> emma.shepherd@diamond.ac.uk
> Sent: Tuesday, November 24, 2009 10:52 AM
> To: tech-talk@aps.anl.gov
> Subject: Modbus help
> Hi,
> I'm trying to get an RS-485 chain of N2300 temperature
> monitors talking to EPICS using the asyn modbus support
> (R1-3) and so far am not having much luck.  Basically I just
> get no response back from any of them, although I'm pretty
> confident I'm sending out the right message (I checked it
> with a serial analyser) and have configured the correct comms setting.
> After iocInit I get the following message on the console
> (with asynTrace turned on):
> 2009/11/24 16:03:34.302 drvModbusAsyn::doModbusIO port
> readTemp is disconnected
> and then lots of I/O errors:
> 02 03 00 01 00 01 d5 f9
> 2009/11/24 16:03:38.952 drvModbusAsyn::doModbusIO port
> readTemp error calling writeRead, error=, nwrite=5/5, nread=0
> 2009/11/24 16:03:39.302 ME02P-DI-TMON-01:TEMP1
> devAsynFloat64::process read error 2009/11/24 16:03:40.452
> drvModbusAsyn::doModbusIO port readTemp has I/O error
> 2009/11/24 16:03:40.452 /ty/72/0 write 8
> 2009/11/24 16:03:41.952 drvModbusAsyn::doModbusIO port
> 2009/11/24 16:03:43.452 drvModbusAsyn::doModbusIO port
> readTemp has I/O error 2009/11/24 16:03:43.452 /ty/72/0 write 8
> ....... etc
> asynReport prints the following:
> modbus port: readTemp
>     asynOctet server:   ty_72_0
>     modbusFunction:     3
>     modbusStartAddress: 01
>     modbusLength:       01
>     plcType:            N2300
>     I/O errors:         119
>     Read OK:            0
>     Write OK:           0
>     pollDelay:          1.500000
>     Time for last I/O   0 msec
>     Max. I/O time:      0 msec
> value = 0 = 0x0
> Am I likely to be chasing a wiring/hardware issue here or is
> there something standing out that indicates a problem higher
> up? This is the first time I've tried to use modbus so I'm
> not sure what a 'working' system looks like!
> Thanks in advance,
> Emma
> This e-mail and any attachments may contain confidential,
> copyright and or privileged material, and are for the use of
> the intended addressee only. If you are not the intended
> addressee or an authorised recipient of the addressee please
> notify us of receipt by returning the e-mail and do not use,
> copy, retain, distribute or disclose the information in or
> attached to the e-mail. Any opinions expressed within this
> e-mail are those of the individual and not necessarily of
> Diamond Light Source Ltd.
> Diamond Light Source Ltd. cannot guarantee that this e-mail
> or any attachments are free from viruses and we cannot accept
> liability for any damage which you may sustain as a result of
> software viruses which may be transmitted in or with the
> message. Diamond Light Source Limited (company no. 4375679).
> Registered in England and Wales with its registered office at
> Diamond House, Harwell Science and Innovation Campus, Didcot,
> Oxfordshire, OX11 0DE, United Kingdom
#!$(INSTALL)/bin/$(ARCH)/ME02P-MO-IOC-01
# Following line enables the backspace key
$(VXWORKS_ONLY)tyBackspaceSet(127)
# IP site enumerations
$(VXWORKS_ONLY)A = 0
$(VXWORKS_ONLY)B = 1
$(VXWORKS_ONLY)C = 2
$(VXWORKS_ONLY)D = 3
## You may have to change polarimeter to something else
## everywhere it appears in this file
cd "$(INSTALL)"
# Load binaries on architectures that need to do so.
# VXWORKS_ONLY, LINUX_ONLY and RTEMS_ONLY are macros that resolve
# to a comment symbol on architectures that are not the current
# build architecture, so they can be used liberally to do architecture
# specific things. Alternatively, you can include an architecture
# specific file.
$(VXWORKS_ONLY)ld < bin/$(ARCH)/ME02P-MO-IOC-01.munch
# Set CA_MAX_ARRAY_BYTES for sscan software
epicsEnvSet("EPICS_CA_MAX_ARRAY_BYTES","3000000")
## This drvTS initializer is needed if the IOC has a hardware event system
#TSinit
dbLoadDatabase("dbd/ME02P-MO-IOC-01.dbd")
ME02P_MO_IOC_01_registerRecordDeviceDriver(pdbbase)
# Configure 1 PMAC
$(VXWORKS_ONLY)IVEC=newInterruptVector()
pmacVmeDebug=1
drvPmacDebug=1
pmacVmeConfig(0, 0x7fa000, 0x700000, 0xC1, 3)
# Startup driver for DPRAM ASCII buffer
pmacVmeDebug=0
drvPmacDebug=0
pmacAsynConfig(0, "PMAC_S")
# Configure Old-style and DPRAM interface for first PMAC card.
pmacDrvConfig (0,-1,-1,0,"PMAC_S0")
# Initialise the low-level PMAC driver (comms port, comms addr, card, nAxes)
pmacAsynMotorCreate("PMAC_S0", 0, 0, 32, 0x1)
# Setup the motor Asyn layer (portname, low-level driver drvet name, card, number of axes on card)
drvAsynMotorConfigure("PMAC1", "pmacAsynMotor", 0, 33)
# Configure Hytec carriers
# 8002 Carrier in VME Slot 7
$(VXWORKS_ONLY)ARGS7 = malloc(20)
$(VXWORKS_ONLY)IVEC7 = newInterruptVector()
$(VXWORKS_ONLY)sprintf(ARGS7, "7 2 %d", IVEC7)
$(VXWORKS_ONLY)IPAC7 = ipacAddHy8002(ARGS7)
# 8512 scalar module in IP site A of IP carrier card in slot 7
$(VXWORKS_ONLY)IVEC70 = newInterruptVector()
DLS8512Configure(700, IPAC7, A, IVEC70)
# 8515 serial module in IP site B of IP carrier card in slot 7
# (Currently unused)
$(VXWORKS_ONLY)IVEC = newInterruptVector()
$(VXWORKS_ONLY)SER71 = Hy8515Configure(71, IPAC7, B, IVEC, 625, 0, 0)
$(VXWORKS_ONLY)S710 = tyHYOctalDevCreate("/ty/71/0", SER71, 0, 2500, 2500)
# 8516 serial module in IP site C of IP carrier card in slot 7
$(VXWORKS_ONLY)SER72 = Hy8515Configure(72, IPAC7, C, IVEC, 625, 2, 0)
$(VXWORKS_ONLY)S720 = tyHYOctalDevCreate("/ty/72/0", SER72, 0, 256, 256)
# Set Hytec parameters
# Params are :
#       Port
#       Baud rate
#       Parity 'O'=odd, 'E'=even, 'N'=none
#       Number of stop bits. 1 or 2
#       Number of data bits. 5,6,7 or 8
#       Flow control. 'R'=receive only, 'T'=transmit only, 'H'=both, 'N'=none, 'S'=software
$(VXWORKS_ONLY)tyHYOctalConfig (S720, 4800, 'N', 1, 8, 'N')
# Configure the asyn port for the temperature monitor
drvAsynSerialPortConfigure("ty_72_0", "/ty/72/0", 0, 1, 0)
# Following lines crash the IOC!
#asynSetOption("ty_72_0",0,"baud","4800")
#asynSetOption("ty_72_0",0,"parity","none")
#asynSetOption("ty_72_0",0,"bits","8")
#asynSetOption("ty_72_0",0,"stop","1")
# Link Type
# 0 TCP/IP
# 1 RTU
# 2 ASCII
#modbusInterposeConfig(portName,slaveAddress,linkType,timeoutMsec)
modbusInterposeConfig("ty_72_0", 1, 1, 1500)
#drvModbusAsynConfigure(portName,tcpPortName,modbusFunction,modbusStartAddress,modbusLength,dataType,pollMsec,plcType);
modbusRead = 3
drvModbusAsynConfigure("readTemp", "ty_72_0", modbusRead, 1, 1, 0, 1500, "N2300")
#drvModbusAsynConfigure("readSetpoint", "ty_72_0", modbusRead, 2, 1, 0, 1500, "N2300")
asynSetTraceMask  ("ty_72_0", 0, 8)
asynSetTraceIOMask("ty_72_0", 0, 4)
asynSetTraceMask("readTemp",0,9)
asynSetTraceIOMask("readTemp",0,4)
## Load record instances
dbLoadRecords("db/ME02P-MO-IOC-01.db")
dbLoadRecords("db/tempMonitor.db")
## Set this to see messages from mySub
#mySubDebug 1
$(VXWORKS_ONLY)STREAM_PROTOCOL_DIR = malloc (1000)
$(VXWORKS_ONLY)strcpy (STREAM_PROTOCOL_DIR, "$(MKS937A)/data")
iocInit()
RE: Modbus help Mark Rivers
Prev: Re: CA problem w EPICS 3.14.11 & VxWorks 6.7 Kazuro FURUKAWA
Next: RE: CA problem w EPICS 3.14.11 & VxWorks 6.7 GOURNAY Jean-Francois
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017
Prev: RE: Modbus help Mark Rivers
Next: RE: Modbus help Mark Rivers
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
