Hi Emma,
I've just had a quick look at your startup script. The only think that catches my eye is the start address of 1. Is this Modbus address supported by the device? I doubt if this is the problem though, because even with an invalid address I think the device should be sending back an error response if it received a command with the correct slave address. Have you checked the simple stuff, like whether you need a null modem (swap pins 2 and 3)?
#drvModbusAsynConfigure(portName,tcpPortName,modbusFunction,modbusStartAddress,modbusLength,dataType,pollMsec,plcType);
modbusRead = 3
drvModbusAsynConfigure("readTemp", "ty_72_0", modbusRead, 1, 1, 0, 1500, "N2300")
Sent: Wed 11/25/2009 3:37 AM
To: Mark Rivers; [email protected]
Subject: RE: Modbus help
Hi Mark,
I've attached my startup script (the modbus stuff is at the bottom).
There are actually 8 devices in an RS-485 chain, at the moment I'm just
trying to talk to the one which is configured with address '1' (although
I have tried the others as well). They use serial/RTU.
I turned on trace for the Modbus port as well, here's what I get:
01 03 00 01 00 01 d5 ca
2009/11/25 09:33:41.823 drvModbusAsyn::doModbusIO port readTemp error
calling writeRead, error=, nwrite=5/5, nread=0
2009/11/25 09:33:42.173 readTemp queueRequest synchronous
2009/11/25 09:33:42.173 ME02P-DI-TMON-01:TEMP1 devAsynFloat64::process
read error
2009/11/25 09:33:43.323 drvModbusAsyn::doModbusIO port readTemp has I/O
error
disconnect device OK
2009/11/25 09:33:43.323 drvModbusAsyn::doModbusIO port readTemp connect
device OK
2009/11/25 09:33:43.323 /ty/72/0 write 8
2009/11/25 09:33:44.823 drvModbusAsyn::doModbusIO port readTemp error
2009/11/25 09:33:46.323 drvModbusAsyn::doModbusIO port readTemp has I/O
error
2009/11/25 09:33:46.323 drvModbusAsyn::doModbusIO port readTemp connect
device OK
2009/11/25 09:33:46.323 /ty/72/0 write 8
Thanks a lot,
Emma
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: 24 November 2009 17:32
> To: Shepherd, Emma (DLSLtd,RAL,DIA); [email protected]
> Hi Emma,
> Here are some questions/suggestions:
> - Can you send your startup script?
> - How have you set the interpose interface, etc?
> - Does your device use serial/RTU (binary) or serial/ASCII protocol?
> - What is the slave address of your device?
> - You have turned on asynTrace for the underlying asyn serial
> port. Please also turn on asynTrace for the Modbus asyn port.
> That should be very helpful.
> Once I know how it is configured I can figure out if those 8
> characters it is sending are correct.
> Mark
> From: [email protected]
> [mailto:[email protected]] On Behalf Of
> [email protected]
> Sent: Tuesday, November 24, 2009 10:52 AM
> To: [email protected]
> Subject: Modbus help
> Hi,
> I'm trying to get an RS-485 chain of N2300 temperature
> monitors talking to EPICS using the asyn modbus support
> (R1-3) and so far am not having much luck. Basically I just
> get no response back from any of them, although I'm pretty
> confident I'm sending out the right message (I checked it
> with a serial analyser) and have configured the correct comms setting.
> After iocInit I get the following message on the console
> (with asynTrace turned on):
> 2009/11/24 16:03:34.302 drvModbusAsyn::doModbusIO port
> readTemp is disconnected
> and then lots of I/O errors:
> 02 03 00 01 00 01 d5 f9
> 2009/11/24 16:03:38.952 drvModbusAsyn::doModbusIO port
> readTemp error calling writeRead, error=, nwrite=5/5, nread=0
> 2009/11/24 16:03:39.302 ME02P-DI-TMON-01:TEMP1
> devAsynFloat64::process read error 2009/11/24 16:03:40.452
> drvModbusAsyn::doModbusIO port readTemp has I/O error
> 2009/11/24 16:03:40.452 /ty/72/0 write 8
> 2009/11/24 16:03:41.952 drvModbusAsyn::doModbusIO port
> 2009/11/24 16:03:43.452 drvModbusAsyn::doModbusIO port
> readTemp has I/O error 2009/11/24 16:03:43.452 /ty/72/0 write 8
> ....... etc
> asynReport prints the following:
> modbus port: readTemp
> asynOctet server: ty_72_0
> modbusFunction: 3
> modbusStartAddress: 01
> modbusLength: 01
> plcType: N2300
> I/O errors: 119
> Read OK: 0
> Write OK: 0
> pollDelay: 1.500000
> Time for last I/O 0 msec
> Max. I/O time: 0 msec
> value = 0 = 0x0
> Am I likely to be chasing a wiring/hardware issue here or is
> there something standing out that indicates a problem higher
> up? This is the first time I've tried to use modbus so I'm
> not sure what a 'working' system looks like!
> Thanks in advance,
> Emma
> This e-mail and any attachments may contain confidential,
> copyright and or privileged material, and are for the use of
> the intended addressee only. If you are not the intended
> addressee or an authorised recipient of the addressee please
> notify us of receipt by returning the e-mail and do not use,
> copy, retain, distribute or disclose the information in or
> attached to the e-mail. Any opinions expressed within this
> e-mail are those of the individual and not necessarily of
> Diamond Light Source Ltd.
> Diamond Light Source Ltd. cannot guarantee that this e-mail
> or any attachments are free from viruses and we cannot accept
> liability for any damage which you may sustain as a result of
> software viruses which may be transmitted in or with the
> message. Diamond Light Source Limited (company no. 4375679).
> Registered in England and Wales with its registered office at
> Diamond House, Harwell Science and Innovation Campus, Didcot,
> Oxfordshire, OX11 0DE, United Kingdom
- RE: Modbus help emma.shepherd
Addition of command primitives to Asyn motor matthew.pearson
Re: Next generation EPICS display manager Darren Dale
<2009>
RE: Modbus help Mark Rivers
<2009>
