Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017
Subject: RE: RE: RE: error building mca6-11
To: <marco_hair@163.com>, "tech-talk" <tech-talk@aps.anl.gov>
Date: Sat, 21 Nov 2009 08:28:04 -0600
I am not sure if a crash is expected if the camera cannot be found under areaDetector 1-4.  I just tried it under areaDetector 1-5, and it did not crash.
What happens if you connect a camera that it can find under areaDetector 1-4?  I want to know if it crashes when you use it in the normal mode where it can connect to a camera.
You can run it under gdb to see where it is crashing.
> gdb ../../bin/linux-x86/prosilicaApp
gdb> run st.cmd.linux
Finally, can you try 1-5?
Sent: Fri 11/20/2009 8:53 PM
To: Mark Rivers; tech-talk
Subject: Re: RE: RE: error building mca6-11
hi, Mark:
  thanks for informing Tim to correct the URL. Now I try to run areaDetector1.4 under fedora10,  while ioc crashes, erros is shown as following. I want to know if the camera can't be connected, the ioc will crash by an Segmentation fault error?  To clarify it, do you need a core dump file to debug it?
  thanks a lot for your help.
[root@cow2]:/usr/local/epics/r3.14.10/support/areaDetector/1-4/iocBoot/iocProsilica>../../bin/linux-x86/prosilicaApp st.cmd.linux
< envPaths.linux
epicsEnvSet("ARCH","linux-x86")
epicsEnvSet("IOC","iocaaa")
epicsEnvSet("TOP","/usr/local/epics/r3.14.10/support/areaDetector/1-4")
epicsEnvSet("EPICS_BASE","/usr/local/epics/r3.14.10/base")
epicsEnvSet("AREA_DETECTOR","/usr/local/epics/r3.14.10/support/areaDetector/1-4")
epicsEnvSet("AUTOSAVE","/usr/local/epics/r3.14.10/support/autosave/4-5")
< st.cmd
errlogInit(20000)
dbLoadDatabase("/usr/local/epics/r3.14.10/support/areaDetector/1-4/dbd/prosilicaApp.dbd")
prosilicaApp_registerRecordDeviceDriver(pdbbase)
prosilicaConfig("PS1", 51039, 50, 200000000)
2009/11/22 10:57:30.894 prosilica:connectCamera: Cannot find camera 51039
prosilica:prosilica: cannot connect to camera 51039, manually connect when available.
asynSetTraceIOMask("PS1",0,2)
#asynSetTraceMask("PS1",0,255)
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/ADBase.template",   "P=13PS1:,R=cam1:,PORT=PS1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDFile.template",   "P=13PS1:,R=cam1:,PORT=PS1,ADDR=0,TIMEOUT=1")
# Note that prosilica.template must be loaded after NDFile.template to replace the file format correctly
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/prosilica.template","P=13PS1:,R=cam1:,PORT=PS1,ADDR=0,TIMEOUT=1")
#prosilicaConfig("PS2", 50022, 10, 50000000)
#dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/ADBase.template",   "P=13PS1:,R=cam2:,PORT=PS2,ADDR=0,TIMEOUT=1")
#dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/prosilica.template","P=13PS1:,R=cam2:,PORT=PS2,ADDR=0,TIMEOUT=1")
# Create a standard arrays plugin, set it to get data from first Prosilica driver.
drvNDStdArraysConfigure("PS1Image", 5, 0, "PS1", 0, -1)
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDPluginBase.template","P=13PS1:,R=image1:,PORT=PS1Image,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PS1,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDStdArrays.template", "P=13PS1:,R=image1:,PORT=PS1Image,ADDR=0,TIMEOUT=1,SIZE=8,FTVL=UCHAR,NELEMENTS=4177920")
# Load the database to use with Stephen Mudie's IDL code
#dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/EPICS_AD_Viewer.template", "P=13PS1:, R=image1:")
# Create a file saving plugin
drvNDFileConfigure("PS1File", 5, 0, "PS1", 0)
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDPluginBase.template","P=13PS1:,R=file1:,PORT=PS1File,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PS1,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDFile.template",      "P=13PS1:,R=file1:,PORT=PS1File,ADDR=0,TIMEOUT=1")
# Create an ROI plugin
drvNDROIConfigure("PS1ROI", 5, 0, "PS1", 0, 10, 20, -1)
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDPluginBase.template","P=13PS1:,R=ROI1:,  PORT=PS1ROI,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PS1,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDROI.template",       "P=13PS1:,R=ROI1:,  PORT=PS1ROI,ADDR=0,TIMEOUT=1")
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDROIN.template",      "P=13PS1:,R=ROI1:0:,PORT=PS1ROI,ADDR=0,TIMEOUT=1,HIST_SIZE=256")
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDROIN.template",      "P=13PS1:,R=ROI1:1:,PORT=PS1ROI,ADDR=1,TIMEOUT=1,HIST_SIZE=256")
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDROIN.template",      "P=13PS1:,R=ROI1:2:,PORT=PS1ROI,ADDR=2,TIMEOUT=1,HIST_SIZE=256")
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDROIN.template",      "P=13PS1:,R=ROI1:3:,PORT=PS1ROI,ADDR=3,TIMEOUT=1,HIST_SIZE=256")
# Create 2 color conversion plugins
drvNDColorConvertConfigure("PS1CC1", 5, 0, "PS1", 0, 20, -1)
NDPluginColorConvert:NDPluginColorConvert: failed to set integer param for color mode
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDPluginBase.template","   P=13PS1:,R=CC1:,  PORT=PS1CC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PS1,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDColorConvert.template", "P=13PS1:,R=CC1:,  PORT=PS1CC1,ADDR=0,TIMEOUT=1")
drvNDColorConvertConfigure("PS1CC2", 5, 0, "PS1", 0, 20, -1)
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDPluginBase.template","   P=13PS1:,R=CC2:,  PORT=PS1CC2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PS1CC1,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDColorConvert.template", "P=13PS1:,R=CC2:,  PORT=PS1CC2,ADDR=0,TIMEOUT=1")
#set_requestfile_path("./")
#set_savefile_path("./autosave")
#set_requestfile_path("$(AREA_DETECTOR)/ADApp/Db")
#set_pass0_restoreFile("auto_settings.sav")
#set_pass1_restoreFile("auto_settings.sav")
#save_restoreSet_status_prefix("13PS1:")
#dbLoadRecords("$(AUTOSAVE)/asApp/Db/save_restoreStatus.db", "P=13PS1:")
iocInit()
Starting iocInit
## EPICS R3.14.10 $R3-14-10$ $2008/10/27 19:39:04$
## EPICS Base built Nov 12 2009
2009/11/22 10:57:31.418 13PS1:cam1:AcquirePeriod_RBV devAsynFloat64::process read error asynPortDriver:readFloat64: status=3, function=26, value=0.000000
2009/11/22 10:57:31.418 13PS1:cam1:AcquireTime_RBV devAsynFloat64::process read error asynPortDriver:readFloat64: status=3, function=25, value=0.000000
2009/11/22 10:57:31.418 13PS1:cam1:PSFrameRate_RBV devAsynFloat64::process read error asynPortDriver:readFloat64: status=3, function=63, value=0.000000
2009/11/22 10:57:31.418 13PS1:cam1:Manufacturer_RBV devAsynOctet: readIt failed asynPortDriver:readOctet: status=3, function=1, value=
The CA server's beacon address list was empty after initialization?
2009/11/22 10:57:31.419 13PS1:cam1:Model_RBV devAsynOctet: readIt failed asynPortDriver:readOctet: status=3, function=2, value=
#asynSetTraceMask("PS1",0,1)
2009/11/22 10:57:31.419 13PS1:cam1:PSDriverType_RBV devAsynOctet: readIt failed asynPortDriver:readOctet: status=3, function=61, value=
# save things every thirty seconds
2009/11/22 10:57:31.419 13PS1:cam1:PSFilterVersion_RBV devAsynOctet: readIt failed asynPortDriver:readOctet: status=3, function=62, value=
create_monitor_set("auto_settings.req", 30,"P=13PS1:,D=cam1:")
2009/11/22 10:57:31.420 13PS1:cam1:Strobe1Delay_RBV devAsynFloat64::process read error asynPortDriver:readFloat64: status=3, function=84, value=0.000000
2009/11/22 10:57:31.420 13PS1:cam1:Strobe1Duration_RBV devAsynFloat64::process read error asynPortDriver:readFloat64: status=3, function=86, value=0.000000
2009/11/22 10:57:31.420 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.420 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.420 prosilica:writeFloat64: error, status=3 function=26, value=0.010000
2009/11/22 10:57:31.420 13PS1:cam1:AcquirePeriod devAsynFloat64 process error
2009/11/22 10:57:31.420 prosilica:writeFloat64: error, status=3 function=25, value=0.000000
2009/11/22 10:57:31.420 13PS1:cam1:AcquireTime devAsynFloat64 process error
2009/11/22 10:57:31.420 prosilica:writeFloat64: error, status=3 function=3, value=1.000000
2009/11/22 10:57:31.420 13PS1:cam1:Gain devAsynFloat64 process error
save_restore:readReqFile: unable to open file ADBase_settings.req. Exiting.
2009/11/22 10:57:31.421 prosilica:writeFloat64: error, status=3 function=34, value=0.000000
2009/11/22 10:57:31.421 13PS1:cam1:ShutterCloseDelay devAsynFloat64 process error
2009/11/22 10:57:31.421 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.421 prosilica:setGeometry: error, status=3
save_restore:readReqFile: unable to open file NDFile_settings.req. Exiting.
2009/11/22 10:57:31.421 prosilica:writeFloat64: error, status=3 function=33, value=0.000000
2009/11/22 10:57:31.421 13PS1:cam1:ShutterOpenDelay devAsynFloat64 process error
save_restore:readReqFile: unable to open file NDPluginBase_settings.req. Exiting.
save_restore:readReqFile: unable to open file NDStdArrays_settings.req. Exiting.
2009/11/22 10:57:31.421 prosilica:writeFloat64: error, status=3 function=84, value=0.000000
2009/11/22 10:57:31.421 13PS1:cam1:Strobe1Delay devAsynFloat64 process error
2009/11/22 10:57:31.421 prosilica:writeFloat64: error, status=3 function=86, value=0.000000
2009/11/22 10:57:31.421 13PS1:cam1:Strobe1Duration devAsynFloat64 process error
2009/11/22 10:57:31.421 prosilica:writeFloat64: error, status=3 function=35, value=0.000000
2009/11/22 10:57:31.421 13PS1:cam1:Temperature devAsynFloat64 process error
save_restore:readReqFile: unable to open file NDROI_settings.req. Exiting.
save_restore:readReqFile: unable to open file NDROIN_settings.req. Exiting.
2009/11/22 10:57:31.422 13PS1:cam1:Strobe1CtlDuration_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=85, value=0
2009/11/22 10:57:31.422 13PS1:cam1:SyncIn1Level_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=72, value=0
2009/11/22 10:57:31.422 13PS1:cam1:SyncIn2Level_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=73, value=0
2009/11/22 10:57:31.422 13PS1:cam1:SyncOut1Invert_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=76, value=0
2009/11/22 10:57:31.422 13PS1:cam1:SyncOut1Level_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=75, value=0
2009/11/22 10:57:31.422 13PS1:cam1:SyncOut2Invert_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=79, value=0
2009/11/22 10:57:31.422 13PS1:cam1:SyncOut2Level_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=78, value=0
2009/11/22 10:57:31.422 13PS1:cam1:SyncOut3Invert_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=82, value=0
2009/11/22 10:57:31.422 13PS1:cam1:SyncOut3Level_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=81, value=0
2009/11/22 10:57:31.422 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.422 prosilica:setGeometry: error, status=3
save_restore:readReqFile: unable to open file NDColorConvert_settings.req. Exiting.
2009/11/22 10:57:31.422 prosilica:writeInt32: error, status=3 function=59, value=1
2009/11/22 10:57:31.422 13PS1:cam1:ArrayCallbacks devAsynInt32 process error
2009/11/22 10:57:31.422 prosilica:writeInt32: error, status=3 function=44, value=0
2009/11/22 10:57:31.423 13PS1:cam1:AutoIncrement devAsynInt32 process error
2009/11/22 10:57:31.423 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.423 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.423 prosilica:writeInt32: error, status=3 function=47, value=0
2009/11/22 10:57:31.423 13PS1:cam1:AutoSave devAsynInt32 process error
2009/11/22 10:57:31.423 prosilica:writeInt32: error, status=3 function=12, value=0
2009/11/22 10:57:31.423 13PS1:cam1:ReverseX devAsynInt32 process error
2009/11/22 10:57:31.424 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.424 prosilica:writeInt32: error, status=3 function=13, value=0
2009/11/22 10:57:31.424 13PS1:cam1:ReverseY devAsynInt32 process error
2009/11/22 10:57:31.424 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.424 prosilica:writeInt32: error, status=3 function=29, value=0
2009/11/22 10:57:31.424 13PS1:cam1:ShutterControl devAsynInt32 process error
2009/11/22 10:57:31.425 prosilica:writeInt32: error, status=3 function=85, value=0
2009/11/22 10:57:31.425 13PS1:cam1:Strobe1CtlDuration devAsynInt32 process error
2009/11/22 10:57:31.425 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.425 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.425 prosilica:writeInt32: error, status=3 function=76, value=0
2009/11/22 10:57:31.425 13PS1:cam1:SyncOut1Invert devAsynInt32 process error
2009/11/22 10:57:31.425 prosilica:writeInt32: error, status=3 function=75, value=0
2009/11/22 10:57:31.425 13PS1:cam1:SyncOut1Level devAsynInt32 process error
2009/11/22 10:57:31.426 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.426 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.426 prosilica:writeInt32: error, status=3 function=79, value=0
2009/11/22 10:57:31.426 13PS1:cam1:SyncOut2Invert devAsynInt32 process error
2009/11/22 10:57:31.426 prosilica:writeInt32: error, status=3 function=78, value=0
2009/11/22 10:57:31.426 13PS1:cam1:SyncOut2Level devAsynInt32 process error
2009/11/22 10:57:31.427 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.427 prosilica:writeInt32: error, status=3 function=82, value=0
2009/11/22 10:57:31.427 13PS1:cam1:SyncOut3Invert devAsynInt32 process error
2009/11/22 10:57:31.427 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.427 prosilica:writeInt32: error, status=3 function=81, value=0
2009/11/22 10:57:31.427 13PS1:cam1:SyncOut3Level devAsynInt32 process error
2009/11/22 10:57:31.427 13PS1:cam1:MaxSizeX_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=10, value=0
2009/11/22 10:57:31.427 13PS1:cam1:MaxSizeY_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=11, value=0
2009/11/22 10:57:31.428 13PS1:cam1:PSBadFrameCounter_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=71, value=0
2009/11/22 10:57:31.428 13PS1:cam1:PSFramesCompleted_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=64, value=0
2009/11/22 10:57:31.428 13PS1:cam1:PSFramesDropped_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=65, value=0
2009/11/22 10:57:31.428 13PS1:cam1:PSPacketsErroneous_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=66, value=0
2009/11/22 10:57:31.428 13PS1:cam1:PSPacketsMissed_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=67, value=0
2009/11/22 10:57:31.428 13PS1:cam1:PSPacketsReceived_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=68, value=0
2009/11/22 10:57:31.428 13PS1:cam1:PSPacketsRequested_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=69, value=0
2009/11/22 10:57:31.428 13PS1:cam1:PSPacketsResent_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=70, value=0
2009/11/22 10:57:31.428 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.429 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.429 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.429 prosilica:writeInt32: error, status=3 function=4, value=1
2009/11/22 10:57:31.429 13PS1:cam1:BinX devAsynInt32 process error
2009/11/22 10:57:31.429 prosilica:writeInt32: error, status=3 function=5, value=1
2009/11/22 10:57:31.429 13PS1:cam1:BinY devAsynInt32 process error
2009/11/22 10:57:31.429 prosilica:writeInt32: error, status=3 function=42, value=0
2009/11/22 10:57:31.429 13PS1:cam1:FileNumber devAsynInt32 process error
2009/11/22 10:57:31.429 prosilica:writeInt32: error, status=3 function=6, value=0
2009/11/22 10:57:31.429 13PS1:cam1:MinX devAsynInt32 process error
2009/11/22 10:57:31.429 prosilica:writeInt32: error, status=3 function=7, value=0
2009/11/22 10:57:31.429 13PS1:cam1:MinY devAsynInt32 process error
2009/11/22 10:57:31.429 prosilica:writeInt32: error, status=3 function=51, value=0
2009/11/22 10:57:31.429 13PS1:cam1:NumCapture devAsynInt32 process error
2009/11/22 10:57:31.430 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.430 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.430 prosilica:writeInt32: error, status=3 function=23, value=1
2009/11/22 10:57:31.430 13PS1:cam1:NumExposures devAsynInt32 process error
2009/11/22 10:57:31.430 prosilica:writeInt32: error, status=3 function=24, value=0
2009/11/22 10:57:31.430 13PS1:cam1:NumImages devAsynInt32 process error
2009/11/22 10:57:31.430 prosilica:writeInt32: error, status=3 function=8, value=1
2009/11/22 10:57:31.430 13PS1:cam1:SizeX devAsynInt32 process error
2009/11/22 10:57:31.430 prosilica:writeInt32: error, status=3 function=9, value=1
2009/11/22 10:57:31.430 13PS1:cam1:SizeY devAsynInt32 process error
2009/11/22 10:57:31.430 13PS1:cam1:Strobe1Mode_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=83, value=0
2009/11/22 10:57:31.430 13PS1:cam1:SyncOut1Mode_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=74, value=0
2009/11/22 10:57:31.433 13PS1:cam1:SyncOut2Mode_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=77, value=0
2009/11/22 10:57:31.434 13PS1:cam1:SyncOut3Mode_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=80, value=0
2009/11/22 10:57:31.434 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.434 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.434 prosilica:writeInt32: error, status=3 function=19, value=0
2009/11/22 10:57:31.434 13PS1:cam1:ColorMode devAsynInt32 process error
2009/11/22 10:57:31.434 prosilica:writeInt32: error, status=3 function=18, value=1
2009/11/22 10:57:31.434 13PS1:cam1:DataType devAsynInt32 process error
2009/11/22 10:57:31.435 prosilica:writeInt32: error, status=3 function=46, value=0
2009/11/22 10:57:31.435 13PS1:cam1:FileFormat devAsynInt32 process error
2009/11/22 10:57:31.435 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.435 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.435 prosilica:writeInt32: error, status=3 function=50, value=0
2009/11/22 10:57:31.435 13PS1:cam1:FileWriteMode devAsynInt32 process error
2009/11/22 10:57:31.435 prosilica:writeInt32: error, status=3 function=20, value=0
2009/11/22 10:57:31.435 13PS1:cam1:FrameType devAsynInt32 process error
2009/11/22 10:57:31.436 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.436 prosilica:writeInt32: error, status=3 function=21, value=0
2009/11/22 10:57:31.436 13PS1:cam1:ImageMode devAsynInt32 process error
2009/11/22 10:57:31.436 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.436 prosilica:writeInt32: error, status=3 function=32, value=0
2009/11/22 10:57:31.436 13PS1:cam1:ShutterMode devAsynInt32 process error
2009/11/22 10:57:31.437 prosilica:writeInt32: error, status=3 function=83, value=0
2009/11/22 10:57:31.437 13PS1:cam1:Strobe1Mode devAsynInt32 process error
2009/11/22 10:57:31.437 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.437 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.437 prosilica:writeInt32: error, status=3 function=74, value=0
2009/11/22 10:57:31.437 13PS1:cam1:SyncOut1Mode devAsynInt32 process error
2009/11/22 10:57:31.437 prosilica:writeInt32: error, status=3 function=77, value=0
2009/11/22 10:57:31.437 13PS1:cam1:SyncOut2Mode devAsynInt32 process error
2009/11/22 10:57:31.438 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.438 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.438 prosilica:writeInt32: error, status=3 function=80, value=0
2009/11/22 10:57:31.438 13PS1:cam1:SyncOut3Mode devAsynInt32 process error
2009/11/22 10:57:31.438 prosilica:writeInt32: error, status=3 function=22, value=0
2009/11/22 10:57:31.438 13PS1:cam1:TriggerMode devAsynInt32 process error
fc10 epics> Segmentation fault
======= At 2009-11-21, 01:44:18 you wrote: =======
>Hi Geyang,
>I am running areaDetector on several different versions of Linux.  These
>include:
>Fedora Core 9 (2.6.27)
>Fedora Core 10 (2.6.27)
>SUSE 2.6.22
>Redhat (2.6.18)
>Mark
>-----Original Message-----
>From: Silver [mailto:marco_hair@163.com]
>Sent: Friday, November 20, 2009 8:22 AM
>To: Mark Rivers
>Subject: Re: RE: error building mca6-11
>hi, Mark:
>  Thanks for you replay. I will check it later. anyway, it can be
>compiled on fedora system. so as you said, it must be with the version
>of linux or gnu.
>  while I want to ask more questions about the module of
>areadetector(http://cars9.uchicago.edu/software/epics/areaDetector.html)
>. on it, you list the software version and its required modules version.
>for example, version 1.5 should need busy record 1.2, I can only find
>version 1.1 version busy record (http://www.aps.anl.gov/bcda/synApps/).
>Is it possible for you to give a url for those required modules?
>  ps, could you tell me your linux version running areadector?
>======= At 2009-11-20, 21:41:39 you wrote: =======
>>Hi Geyang,
>>I have not seen that problem.
>>But I can see that the problem is that the type u_int32_t is not
>defined.  This probably has to do with the version of Linux or the gnu
>compiler you are using.
>>The file libnet-headers.h, which is included before libnet-functions.h
>in libnet.h, contains the following line:
>>typedef uint32_t u_int32_t;
>>So the problem must be that the type uint32_t is not defined.
>>In a search of typedefs for uint32_t on my system I see that it is
>defined in several files, including /usr/include/stdint.h.
>>For some reason it is not being defined when you build libnet.  You
>could try adding:
>>#include <stdint.h>
>>before the line
>>#include <libnet.h>
>>in nmc_sys_defs.h
>>and see if that fixes the problem.
>>Mark
>>________________________________
>>Sent: Thu 11/19/2009 11:28 PM
>>To: tech-talk
>>Cc: Mark Rivers
>>Subject: error building mca6-11
>>hi,
>>when I tried to compile the mcaR6-11/10, I met following errors:
>>/usr/bin/gcc-4.2 -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
>-D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux
>-D_REENTRANT -ansi   -O3   -Wall     -g `libnet-config --defines`   -m32
>-g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux
>-I../../../include
>-I/usr/local/epics/r3.14.10/modules/soft/seq/2-0-12/include
>-I/usr/local/epics/r3.14.10/modules/soft/calc/2-6-7/include
>-I/usr/local/epics/r3.14.10/modules/soft/sscan/2-6-5/include
>-I/usr/local/epics/r3.14.10/modules/soft/busy/1-1/include
>-I/usr/local/epics/r3.14.10/modules/soft/std/2-6/include
>-I/usr/local/epics/r3.14.10/modules/soft/asyn/4-12/include
>-I/usr/local/epics/r3.14.10/modules/soft/mca/6-11/include/os/Linux
>-I/usr/local/epics/r3.14.10/base/include/os/Linux
>-I/usr/local/epics/r3.14.10/base/include        ../nmc_comm_subs_1.c
>>In file included from /usr/include/libnet.h:124,
>>                 from ../nmc_sys_defs.h:56,
>>                 from ../nmc_comm_subs_1.c:69:
>>/usr/include/./libnet/libnet-functions.h:1432: error: expected '=',
>',', ';', 'asm' or '__attribute__' before 'u_int32_t'
>>make[3]: *** [nmc_comm_subs_1.o] Error 1
>>make[3]: Leaving directory
>`/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp/CanberraSrc/O.li
>nux-x86'
>>make[2]: *** [install.linux-x86] Error 2
>>make[2]: Leaving directory
>`/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp/CanberraSrc'
>>make[1]: *** [CanberraSrc.install] Error 2
>>make[1]: Leaving directory
>`/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp'
>>make: *** [mcaApp.install] Error 2
>>root@cow1:/usr/local/epics/r3.14.10/modules/soft/mca/6-11#
>>Any suggestion?  thanks a lot.
>>ps, I use ubuntu, libnet1 with apt-get install ,not from source
>compilation.
>>Best regards
>>Geyang  2009-11-20
>Best regards
>Geyang 2009-11-20
Best regards
Geyang 2009-11-21
error building mca6-11 Silver
RE: error building mca6-11 Mark Rivers
Re: RE: RE: error building mca6-11 Silver
Prev: Re: RE: RE: error building mca6-11 Silver
Next: RE: error building mca6-11 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017
Next: RE: error building mca6-11 Davidsaver, Michael
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
