1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: error building mca6-11
To: <[email protected]>, "tech-talk" <[email protected]>
Date: Fri, 20 Nov 2009 07:41:41 -0600
Hi Geyang,
I have not seen that problem.
But I can see that the problem is that the type u_int32_t is not defined.  This probably has to do with the version of Linux or the gnu compiler you are using.
The file libnet-headers.h, which is included before libnet-functions.h in libnet.h, contains the following line:
typedef uint32_t u_int32_t;
So the problem must be that the type uint32_t is not defined.
In a search of typedefs for uint32_t on my system I see that it is defined in several files, including /usr/include/stdint.h.
For some reason it is not being defined when you build libnet.  You could try adding:
#include <stdint.h>
before the line
#include <libnet.h>
in nmc_sys_defs.h
and see if that fixes the problem.
Sent: Thu 11/19/2009 11:28 PM
To: tech-talk
Cc: Mark Rivers
Subject: error building mca6-11
hi,
when I tried to compile the mcaR6-11/10, I met following errors:
/usr/bin/gcc-4.2 -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi   -O3   -Wall     -g `libnet-config --defines`   -m32     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include  -I/usr/local/epics/r3.14.10/modules/soft/seq/2-0-12/include  -I/usr/local/epics/r3.14.10/modules/soft/calc/2-6-7/include  -I/usr/local/epics/r3.14.10/modules/soft/sscan/2-6-5/include  -I/usr/local/epics/r3.14.10/modules/soft/busy/1-1/include  -I/usr/local/epics/r3.14.10/modules/soft/std/2-6/include    -I/usr/local/epics/r3.14.10/modules/soft/asyn/4-12/include -I/usr/local/epics/r3.14.10/modules/soft/mca/6-11/include/os/Linux -I/usr/local/epics/r3.14.10/modules/soft/mca/6-11/include -I/usr/local/epics/r3.14.10/base/include/os/Linux -I/usr/local/epics/r3.14.10/base/include        ../nmc_comm_subs_1.c
In file included from /usr/include/libnet.h:124,
                 from ../nmc_sys_defs.h:56,
                 from ../nmc_comm_subs_1.c:69:
/usr/include/./libnet/libnet-functions.h:1432: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'u_int32_t'
make[3]: *** [nmc_comm_subs_1.o] Error 1
make[3]: Leaving directory `/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp/CanberraSrc/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp/CanberraSrc'
make[1]: *** [CanberraSrc.install] Error 2
make[1]: Leaving directory `/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp'
make: *** [mcaApp.install] Error 2
root@cow1:/usr/local/epics/r3.14.10/modules/soft/mca/6-11#
Any suggestion?  thanks a lot.
ps, I use ubuntu, libnet1 with apt-get install ,not from source compilation.
Best regards
Geyang  2009-11-20
RE: error building mca6-11 Mark Rivers
error building mca6-11 Silver
Prev: error building mca6-11 Silver
Next: RE: error building mca6-11 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
