So out of curiosity is it the 3-14-11 version of base that tells it to
use ncurses instead on curses?
Mark Rivers wrote:
This is what I see on my 64-bit Linux system:
[epics@baja ~]$ ls -l /usr/lib64/*curs*
lrwxrwxrwx 1 root root 19 Nov 2 2007 /usr/lib64/libXcursor.so.1 -> libXcursor.so.1.0.2
-rwxr-xr-x 1 root root 41040 Sep 24 2007 /usr/lib64/libXcursor.so.1.0.2
-rw-r--r-- 1 root root 17 Oct 16 2007 /usr/lib64/libcurses.so
lrwxrwxrwx 1 root root 18 Feb 20 2008 /usr/lib64/libcursesw.so -> libncursesw.so.5.6
lrwxrwxrwx 1 root root 27 Feb 20 2008 /usr/lib64/libncurses.so -> ../../lib64/libncurses.so.5
lrwxrwxrwx 1 root root 16 Feb 20 2008 /usr/lib64/libncursesw.so -> libncursesw.so.5
lrwxrwxrwx 1 root root 18 Nov 2 2007 /usr/lib64/libncursesw.so.5 -> libncursesw.so.5.6
-rwxr-xr-x 1 root root 183264 Oct 16 2007 /usr/lib64/libncursesw.so.5.6
Sent: Thu 9/24/2009 12:17 AM
To: Mark Rivers
Cc: Matthieu Bec; [email protected]
Subject: Re: alarm handler on base 3-14-11
It seems there were too many dependencies to remove, so I did a
reinstall, but that didn't seem to help, and it gave the same warning
that ldconfig did when it reinstalled.
Mark Rivers wrote:
That's what I suspected. I don't think that is right. I would uninstall both packages, make sure those files are gone and reinstall.
Sent: Wed 9/23/2009 11:08 PM
To: Mark Rivers
/usr/lib/libcurses.so seems to be a link to /usr/lib64/libncurses.so.5.5
Mark Rivers wrote:
Do
ls -l /usr/lib64/*curse*
and see what the real files are, what are soft links, etc.
From: [email protected] on behalf of Patrick Thomas
Sent: Wed 9/23/2009 10:54 PM
To: Matthieu Bec
Cc: [email protected]
It said:
/sbin/ldconfig: libraries libcurses.so and libncurses.so.5.5 in directory /usr/lib have same soname but different type.
Matthieu Bec wrote:
Hi Patrick,
try running ldconfig (as root), that might help fix missing softlink etc.
and then rebuild as normal
On 09/23/09 23:38, Patrick Thomas wrote:
I'm not sure. I see the path to /usr/lib64 being used by make, so I'm
confused why it wouldn't find it there.
/usr/bin/g++ -o alh
-L/users/thomas/epics/base/base-3-14-11/lib/linux-x86_64 -L/usr/lib64
-Wl,-rpath,/users/thomas/epics/base/base-3-14-11/lib/linux-x86_64
-Wl,-rpath,/usr/lib64 -m64 alCA.o acknowledge.o alAudio.o alarm.o
alCaCommon.o alConfig.o alFilter.o alLib.o alLog.o alView.o alh.o
awAct.o awAlh.o awEdit.o awView.o axArea.o axRunW.o axSubW.o browser.o
current.o dialog.o file.o force.o guidance.o heartbeat.o help.o line.o
mask.o process.o property.o scroll.o showmask.o sllLib.o beepSevr.o
noAck.o -lca -lCom -lXmu -lXm -lXt -lX11 -lXp -lpthread -lreadline
-lncurses -lm -lrt -ldl -lgcc
/usr/bin/ld: cannot find -lncurses
collect2: ld returned 1 exit status
make[3]: *** [alh] Error 1
make[3]: Leaving directory
`/users/thomas/epics/extensions/src/alh1_2_24/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory
`/users/thomas/epics/extensions/src/alh1_2_24'
make[1]: *** [alh1_2_24.install] Error 2
make[1]: Leaving directory `/users/thomas/epics/extensions/src'
make: *** [src.install] Error 2
Zhichu Chen wrote:
Then maybe your /usr/lib(64) is not included in the LIB variable. It
happened to me before, when I was compiling EDM on a 64bit ubuntu
using GCC 4.3.3, it can't find libXm, blahblah. Well, since that's not
my laptop and I'm not supposed to jeopardize the system environment, I
just make some symbolic links to /base/lib so it can move on to the
next step. I'm not sure if this message could be helpful.
On Thu, Sep 24, 2009 at 10:35 AM, Patrick Thomas
<[email protected]> wrote:
There is a copy there as well.
Mark Rivers wrote:
I think that is the 32-bit version, and you need the 64-bit version,
which
will be in usr/lib64
Sent: Wed 9/23/2009 9:02 PM
To: Zhichu Chen
I think it is installed, there is a libncurses.so.5 file in /usr/lib.
Zhichu Chen wrote:
Install ncurses library by yourself.
On Thu, Sep 24, 2009 at 9:47 AM, Patrick Thomas
Thank you, that seems to have worked. However, now it errors on
'cannot
find
-lncurses' for g++ -o alh.
Mark Rivers wrote:
This is a common change required in 3.14.11.
You need to "#include menuYesNo.h" and YES needs to be changed to
menuYesNoYES.
Sent: Wed 9/23/2009 8:00 PM
To: [email protected]
Subject: alarm handler on base 3-14-11
I was wondering, I get a compile error on force.c when running
make on
the alarm handler with epics-3-14-11, on 64 bit linux:
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux
-D_REENTRANT -O3 -Wall -m64 -g -I. -I../O.Common -I.
-I../os/default -I.. -I../../../include/os/Linux
-I../../../include
-I/users/thomas/epics/base/base-3-14-11/include/os/Linux
-I/users/thomas/epics/base/base-3-14-11/include -I../os/Linux
-I../os/default -I/usr/include -I/usr/include/X11 ../force.c
../force.c: In function 'forcePVUpdateFields':
../force.c:1028: error: 'YES' undeclared (first use in this
function)
../force.c:1028: error: (Each undeclared identifier is reported
only
once
../force.c:1028: error: for each function it appears in.)
make[2]: *** [force.o] Error 1
make[1]: *** [install.linux-x86_64] Error 2
make: *** [alh1_2_24.install] Error 2
Thank you,
Patrick
- alarm handler on base 3-14-11 Patrick Thomas
- RE: alarm handler on base 3-14-11 Mark Rivers
- Re: alarm handler on base 3-14-11 Patrick Thomas
- Re: alarm handler on base 3-14-11 Zhichu Chen
- Re: alarm handler on base 3-14-11 Matthieu Bec
<2009>
<2009>
ANJ, 31 Jan 2014 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
