1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: alarm handler on base 3-14-11
To: Patrick Thomas <[email protected]>
Cc: [email protected]
Date: Thu, 24 Sep 2009 10:44:55 +0800
Then maybe your /usr/lib(64) is not included in the LIB variable. It
happened to me before, when I was compiling EDM on a 64bit ubuntu
using GCC 4.3.3, it can't find libXm, blahblah. Well, since that's not
my laptop and I'm not supposed to jeopardize the system environment, I
just make some symbolic links to /base/lib so it can move on to the
next step. I'm not sure if this message could be helpful.
On Thu, Sep 24, 2009 at 10:35 AM, Patrick Thomas
<[email protected]> wrote:
> There is a copy there as well.
> Mark Rivers wrote:
>> I think that is the 32-bit version, and you need the 64-bit version, which
>> will be in usr/lib64
>>   Mark
>> ________________________________
>> From: [email protected] on behalf of Patrick Thomas
>> Sent: Wed 9/23/2009 9:02 PM
>> To: Zhichu Chen
>> I think it is installed, there is a libncurses.so.5 file in /usr/lib.
>> Zhichu Chen wrote:
>>> Install ncurses library by yourself.
>>> On Thu, Sep 24, 2009 at 9:47 AM, Patrick Thomas
>>>> Thank you, that seems to have worked. However, now it errors on 'cannot
>>>> find
>>>> -lncurses' for g++ -o alh.
>>>> Mark Rivers wrote:
>>>>> This is a common change required in 3.14.11.
>>>>>  You need to "#include menuYesNo.h" and YES needs to be changed to
>>>>> menuYesNoYES.
>>>>>  Mark
>>>>> Sent: Wed 9/23/2009 8:00 PM
>>>>> To: [email protected]
>>>>> Subject: alarm handler on base 3-14-11
>>>>> Hi,
>>>>> I was wondering, I get a compile error on force.c when running make on
>>>>> the alarm handler with epics-3-14-11, on 64 bit linux:
>>>>> /usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
>>>>> -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux
>>>>>  -D_REENTRANT   -O3   -Wall      -m64     -g  -I. -I../O.Common -I.
>>>>> -I../os/default -I.. -I../../../include/os/Linux -I../../../include
>>>>> -I/users/thomas/epics/base/base-3-14-11/include/os/Linux
>>>>> -I/users/thomas/epics/base/base-3-14-11/include         -I../os/Linux
>>>>> -I../os/default -I/usr/include -I/usr/include/X11    ../force.c
>>>>> ../force.c: In function 'forcePVUpdateFields':
>>>>> ../force.c:1028: error: 'YES' undeclared (first use in this function)
>>>>> ../force.c:1028: error: (Each undeclared identifier is reported only
>>>>> once
>>>>> ../force.c:1028: error: for each function it appears in.)
>>>>> make[2]: *** [force.o] Error 1
>>>>> make[2]: Leaving directory
>>>>> `/users/thomas/epics/extensions/src/alh1_2_24/O.linux-x86_64'
>>>>> make[1]: *** [install.linux-x86_64] Error 2
>>>>> make[1]: Leaving directory
>>>>> `/users/thomas/epics/extensions/src/alh1_2_24'
>>>>> make: *** [alh1_2_24.install] Error 2
>>>>> Thank you,
>>>>> Patrick
Best Regards
Chen
          Zhi-chu Chen | Shanghai Synchrotron Radiation Facility
         No. 2019 | Jialuo Rd. | Jiading | Shanghai | P.R. China
             tel: 086 21 5955 3405 | zhichu.chen.googlepages.com
                                               | www.sinap.ac.cn
Re: alarm handler on base 3-14-11 Patrick Thomas
RE: alarm handler on base 3-14-11 Mark Rivers
Re: alarm handler on base 3-14-11 Zhichu Chen
Prev: Re: alarm handler on base 3-14-11 Matthieu Bec
Next: Re: alarm handler on base 3-14-11 Patrick Thomas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: alarm handler on base 3-14-11 Patrick Thomas
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
